Last Active: 6 hours ago
Visits: 38.2K
I just got a message about these. As far as I know FlowKooler is a good company. Chuck
http://www.flowkoolerwaterpumps.com/store/Water-Pumps-Ford-CID:-312/5.1L/c21_30_323/index.html
Posts: 1.4K,
Visits: 7.5K
Got the some message Chuck, looks like a good product.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Last Active: 26 minutes ago
Posts: 2.0K,
Visits: 130.7K
Hey guys is that a full aluminum pump or is just the impeller that is aluminum?
Visits: 4.5K
Daniel Jessup (9/18/2014) Hey guys is that a full aluminum pump or is just the impeller that is aluminum?
This from the specifications...
General Specifications: |
| Type of Material of Pump Body | Cast Iron
| | Number of Blades on Impeller | 16 vane CNC impeller system
| | Direction of Rotation | CW
| | Threaded Bracket Bolt Holes on Pump Body, Number & Size |
| | Mounting Gasket, Number & Thickness |
| | Back Plate Gasket, Number & Thickness |
| | Approximate Shipping Weight in Box, lbs | 9 | Related Specifications: |
| Fan Hub Working Height |
| Shaft Diameter | 5/8" |
| Hub Bolt Holes (Center to Center) |
| Bolt Holes, Number & Size |
| Inlet Outside Diameter |
| Hose Connections | 1st | 2nd |
| Gender |
| Diameter |
| Threaded |
Other Special Features: |
| - 16 blade skip vane CNC Machined Aluminum impeller system
- Impeller protected with a military grade Type II class II anodized surface coating
- See applications to confirm this fits your specific Y Block
Parts Contained in Box: |
| - Mounting Gaskets (2), Backing Gasket 1
- Installation Sheet
- FlowKooler Decal
South Australia
Visits: 38.2K
Thats an interesting change almost like a bait and switch. I read aluminum and went from there. I'd like Ted or John to get one for testing anyway. Chuck
Posts: 3.0K,
Visits: 8.7K
Flow knows how to make pumps, probably works pretty good.
