Aluminum water pumps
http://forums.y-blocksforever.com/Topic107809.aspx
By MoonShadow - 11 Years Ago
I just got a message about these. As far as I know FlowKooler is a good company. Chuck
http://www.flowkoolerwaterpumps.com/store/Water-Pumps-Ford-CID:-312/5.1L/c21_30_323/index.html
By Glen Henderson - 11 Years Ago
Got the some message Chuck, looks like a good product.
By Daniel Jessup - 11 Years Ago
Hey guys is that a full aluminum pump or is just the impeller that is aluminum?
By slick56 - 11 Years Ago
Daniel Jessup (9/18/2014)
This from the specifications...
General Specifications:
 Type of Material of Pump BodyCast Iron
 Number of Blades on Impeller16 vane CNC impeller system
 Direction of RotationCW
 Threaded Bracket Bolt Holes on Pump Body, Number & Size
 Mounting Gasket, Number & Thickness
 Back Plate Gasket, Number & Thickness
 Approximate Shipping Weight in Box, lbs9
Related Specifications:
 Fan Hub Working Height
 Shaft Diameter5/8"
 Hub Bolt Holes (Center to Center)
 Bolt Holes, Number & Size
 Inlet Outside Diameter
 Hose Connections1st2nd
 Gender
 Diameter
 Threaded
Other Special Features:
  • 16 blade skip vane CNC Machined Aluminum impeller system
  • Impeller protected with a military grade Type II class II anodized surface coating
  • See applications to confirm this fits your specific Y Block
Parts Contained in Box:
  • Mounting Gaskets (2), Backing Gasket 1
  • Installation Sheet
  • FlowKooler Decal
Thats an interesting change almost like a bait and switch. I read aluminum and went from there. I'd like Ted or John to get one for testing anyway. Chuck
By pegleg - 11 Years Ago
Flow knows how to make pumps, probably works pretty good.
