Visits: 147
I have a 1955 Ford Crown Vic. I want to change the ignition switch but cannot figure out how to get the key cylinder out of the ignition switch. Any ideas? JDH
JDH: 1955 Ford car, I have switched from 6 volts to 12 volts. Every thing working on 12 volts except now I have no brake lights, no turn signals. I have 12 volts at the brake cylinder. Where have I gone wrong? Turn signals worked on right hand side of car for a short time but quit.
Visits: 3.1K
Its been a while since I have done this but as I recall, you depress the small brass pin, (with the key in I think) and then turn the key until you can remove the cylinder. Sorry i can't remember it exactly so you may have to experiment with turning the key to find the release point. Good luck.
PS JDH, I may have incorrectly assumed that you have the ignition switch removed from the dash. If my assumption was in fact incorrect you will need to do that. Reach behind the dash and pull the switch towards you to release some tension on the spring that hold the switch tight. Then turn the small insert in the middle of the switch about a quarter turn and the switch bezel should then pop off and the switch can be removed from the back. Then you can remove the key cylinder.
Mark
Last Active: 7 days ago
Posts: 1.9K,
Visits: 195.0K
And disconnect the battery first.
Posts: 1.6K,
Visits: 5.2K
I just removed one on a 56 and thought that you had to have the key in the accessory position before depressing the button but as it turned out it had to be in the on position.
