55 Ford Fairlane Refresh and Driver Resto Blog Begins!
Posted By Daniel Jessup 12 Years Ago
Daniel Jessup
Posts: 2.0K, Visits: 131.2K
Big hangup... check this out:
The driver's side floor pan is rotted completely through. A little bit of a setback on the timing here. I thought for sure the floor was pretty solid but that was only by looking from underneath and not really "banging around" with anything. However, when I pulled back the old carpet to throw it out about 2 lbs of rusted metal STUCK TO THE JUTE UNDERLAYMENT and just came right out. I have already had a replacement floor pan shipped in:
I did get the dash installed but only have this photo of some of the assembly on the bench
And, this wiring harness came in today so I have some work ahead of me!
Daniel Jessup
Red Lion, Pennsylvania
Daniel Jessup
Been real busy lately. Found a place to live in Milford earlier this week, and we go to closing on our house here in about 2 weeks or so. I did get the chance to get back with it last night though. I built a "cocoon" around the area that I worked on for the floorpan because I already had the new dash installed and I did not want to ruin the headliner, the door panels, etc. Basically I wrapped the dash in plastic and then put cardboard up all the way around - even to protect the headliner. When I weld and stuff starts spattering hopefully it will protect things.
The old rotten floor came up like butter. However, I was surprised to find how little of the floor was rotten. There was better metal in places than I thought so the section I had to cut out was not too big. I use the holes in the strut as a reference point so that I could trim the new floorboard to size.
The floor brace/strut is very strong so I just took a Roloc to it to clean it up for a sold arc for the mig welder. I did transfer the measurements of the strut to the new floorboard so that I could drill 3/16" holes so that the floorboard can be spot welded to the strut. The rest of perimeter of the new metal was also drilled out for spot welds, but I am going to see what I can get with lap welds in some areas. I primed the new floor with Weld-Thru Primer as well. I have sealer and I also have chassis black paint all ready to be applied once the repair is made. The only thing I will have to do after all of that is redrill the holes for the accelerator pedal.
Hopefully I can get to all of this over the weekend.
Daniel Jessup
Posts: 4.6K, Visits: 39.5K
Daniel,
Milford, CT is about 3 hours from me in New Hampshire and 5 hour from Bill Myrand in Maine. We will have to meet up someday. Maybe at the nostalgia meet at New England dragway. Chuck
Daniel Jessup
MoonShadow (6/6/2015)
Daniel,
Chuck,
I would love to but I need to let you know - the Milford I am speaking of is in OHIO (Bob Martin country out there I reckon). So, in all actuality I will be moving farther away from you.
sorry about the confusion
Daniel Jessup
Well at least you be near the shootouts. See you at one of those. Chuck
Daniel Jessup
You can follow along in the photos below to see the floor pan work. I did cut out all of the rot, checked on the condition of the remaining, and then cut the panel to fit. The panel was then drilled with 3/16" holes for spot welding and then fitted to the floor, shaped, fitted again, shaped, cut, filed, and then fitted one last time. I used the orientation of the body bolts to help with measurements and orienting the new metal correctly.
I did use a "weld through" primer on the top and bottom and it worked pretty well. The conductivity must have been good because I had to dial back my welder because of early blow throughs and all. I also used self tapping sheet metal screws to keep the panel tight to the overlapped floor so the seam would hold pretty good.
The panel is not perfect, but she looks good from underneath. I still need to hit it with sealer and then I will paint both top and bottom with chassis saver paint.
On to other things...
I was glad I had restored the pedal assembly sometime ago. It felt good to just pick it up and bolt it in. I did try to duplicate Ford's original "anti-rattle" fixes by using a spongey type of neoprene for the bracket to rest on the dash (I believe the factory used cloth?). I did that same thing when I mounted the dash too.
Next came the mounting of the aftermarket MP&B Power Booster and Master Cylinder. The instructions given on paper were good, but not very thorough. There was something they missed on their sheet - namely the adapter plate that bolted to the firewall. It held the rubber grommet for the brake pedal rod/lever.
I got everything mocked up and wondered how the lever was going to be sealed to the firewall because the instructions never mentioned. I just figured it was because it fit so many years, blah, blah, and I would have to make one. I actually took measurements and started wondering where I could find some generic grommets so large. I went back to the shipping box to put the MC box back inside and what do you know? The adapter plate was lying there in a plastic bag. I picked it up and knew immediately what it was for.
Then I sighed and said, "Yep, you've got to take it all apart Dufus!"
here is a photo of the booster assembly with the special bracket for the firewall
All went well until I mounted the MC just to check on my bends and mockup for the brake lines. All went well up front - no issues - just the right amount of distance. However, you can see what happened at the rear.
Aaaaaaaaaaaaaaaaaaaaaaarrrrrrrrrrrrrggggggggggghhhhhhhhhh! I am missing just a couple of inches. So... back to the store to get a longer brake line. I will say that the brake lines I had were a complete set from Jackson's Auto Parts but they were a set for original brakes - not for this FrankenFord I am putting together.
However, the booster and MC do fit well and although it is kicked it into the engine compartment more than I would like, it does not interfere with anything.
I did check the fit of the exhaust manifold and what have you just to be sure.
When I get more photos loaded I will tell you about all the fun we are having with the clutch linkage!
Here is the little booger that is so much fun::::
Daniel Jessup
Sirstud1
Posts: 9, Visits: 44
Love the build! I also have a 55 I'm working on... mine will be ratted out tho.. check it out... hope I can turn to u for some advise if things get complicated... lol. https://flic.kr/p/uaF8bN
crownvic55
Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)
Posts: 38, Visits: 154
Daniel,  If, as the saying goes, cleanliness is next to Godliness then you are in very good shape.  Your work is immaculate.  Ben
Ben HessTulsa,OK
Daniel Jessup
The floorpan and quite a bit of the surrounding floor has been cleaned and now painted with Chassis Saver Antique Satin Paint. I had a whole mess of it so I figured why not. I am probably going to use Dyanamat (or something similar) anyway.
The engine compartment is looking better too.
I made up my own bracket for the return spring. You can see it below.
It sure is getting tight around the clutch pivot/steering gear area!
Daniel Jessup
Daniel Jessup
crownvic55 (6/11/2015)
Sirstud1 (6/10/2015)
Thanks fellas, my wife quipped the other day, "Why don't you just put the fenders back on and run it?"
Too much pride in all this I guess. I want it to be the best driver it can be. It's not a show car but my FIL should be pretty happy with it.
Daniel Jessup
