55 Ford Fairlane Refresh and Driver Resto Blog Begins!
Posted By Daniel Jessup 12 Years Ago
Daniel Jessup
Posts: 2.0K, Visits: 131.2K
Holy Cow! What a fun time my 14 year old son and I had last night - the best example of which was when mama came into the garage and said, "What is going on in here?"
My son replied, "Ummm, Dad just almost killed himself when that bellhousing came close to falling on his head..."
Really, you can't make this stuff up! Here's the story:
With the transmission all buttoned up and ready to go, it was time to reattach the bellhousing and get the whole works in position to be reinstalled. First I removed the housing from where it sat bolted to the engine block.
Once it was removed I briefly inspected it, making sure the fork looked good and the clutch release bearing was in place.
While inspecting the housing and considering the plan to hoist back up into position with the transmission, I thought of a good idea - make a couple of pins, or studs, that will help locate the bellhousing to the block when we are reinstalling everything back into the car. Here is a photo of the original 2.5" bolt (7/16, 14 threads per inch) lined up with a 3" bolt that I found in my stash. The four bolts that mate the transmission to the bell, and the four bolts that mate the bell to the engine block all have a 5/8" hex head.
I cut the heads off of two of these bolts and then made a slot for a screwdriver.
So far so good. Next was to bolt the bell to the trans while both units were resting on the workbench.
One note we will give here, I did take another look at everything before putting it down on the floor and noticed that the overdrive lockout lever was flipped the wrong way. The 90 degree was supposed to face in, not out, so we took care of that pretty quickly.
Down to the floor gently went the whole works, and the transmission was placed on sheet of thick cardboard to help it slide into position.
There is a crossmember towards the rear that must be cleared first, so essentially the tailhousing must be lifted up first and slid backwards in order for the bell to clear the clutch/flywheel.
This is where it got really sticky. Tried as we might, there was no way for the bell to clear the clutch pressure plate assembly as it was jacked into position. The more I think about it now, it may just be that the replacement clutch, though working normally, is much taller (in essence thicker) than the original 55/56 parts. (Remember two things here - I had no original assembly to compare because this was a switch from an automatic to a standard, and secondly I had installed the engine and transmission as a combination when they first went in together.)
I must have spent an hour with my son just trying to figure out how to clear, make more room, etc. There was no way it was going to work. My body went through several configurations as I went into Gumby mode. Often tied up like a pretzel, placing my arms and legs for leverage/power, smearing grease all over my body, on the creeper/off the creeper, charlie horses in my left leg, my son trying to operate the jack, and me wrestling with a stubborn assembly of cast iron. It was indeed a show - we could have sold tickets! BigGrin So, we did the hard thing... the assembly was pulled back out, the bellhousing was unbolted from the transmission and we made plans to lift the two into position and then bolt the two together before sliding the final assembly forward. I am not so sure that is the way it is supposed to work but here is how we did it and where the bellhousing almost took my head off:
1. The transmission was jacked up into position, slid back as far as it would go against the permanent cross member.
2. The bellhousing was lifted up into position and held there using the pins I had made earlier - since they were so long, the bell had room to slide back and forth as needed.
3. The real issue is that at first I did not use the pins, just the shallow studs on the block itself that are used to orient the bell to the block. Big mistake. As I was trying to move a spark plug wire out of the way the bell came down pretty heavily while I was on the creeper and underneath of the whole works. I saw it in time so no injury and everything is ok but good grief it was getting ridiculous at this point. I would have paid good money to have a full size car lift Saturday night!
4. The transmission was inched forward and the bell moved backwards until the holes lined up. One by one the bolts were reinstalled, clearances checked, and back onto the block. The locator pins made it a breeze really. My big issue was getting the bell to clear.
Once we were lined up, I pulled the two access grommets inside the car just below the firewall and installed the two bolts up top:
Now to get everything else where it needs to be. How I can turn a 1 hour project into 3 hours I have no idea, but I am becoming an expert! Tongue
Daniel Jessup
Red Lion, Pennsylvania
Daniel Jessup
For those of you that cannot view these photos in your browse, I did find a fix for Mozilla and Google Chrome browsers. Please read this post from the HAMB...
"I found these links posted over at T.R.A.K last week by Bernard Kron. The Mozilla link worked for me.
Post by Bernard Kron on Aug 27, 2017 at 4:41pm An add-on (plug-in) has been developed, originally for Chrome and now ported over to Mozilla Firefox, that re-establishes the links to all Photobucket images that have been blocked with the Photobucket "Logo of Death" (see below. So far it's available only for Firefox & Google Chrome browsers. I will update this post if it emerges for Microsoft Internet Explorer, Edge or other popular browsers.
For Google Chrome users open Chrome and navigate here: github.com/kzahel/photobucket-embed-fix ; or here: chrome.google.com/webstore/detail/photobucket-embed-fix/naolkcpnnlofnnghnmfegnfnflicjjgj?hl=en
For Mozilla Firefox users open Firefox (v. 48 and above) and go here: addons.mozilla.org/en-US/firefox/addon/photobucket-embedded-fix/?src=ss
end quote"
Daniel Jessup
kevink1955
Posts: 236, Visits: 237.6K
Thanks Daniel, that fix for FireFox works.
Posts: 4.6K, Visits: 39.5K
I'm using internet explorer and cant see the pictures.
Daniel Jessup
Fellas,
It has been a long time since I have posted anything to this thread... I did want to let you know that I began my own website, www.hotrodreverend.com. Much of that was due to the issues with photobucket and not being able to have third party hosting for the media I had saved and posted on three different websites. Making my own gave me liberty and license to design what I wanted. With over 26,000 views on this forum alone, I would imagine that some of you would like to continue to follow the action on the 55 Fairlane.
Simply go to this address to view the blog:
https://www.hotrodreverend.com/in-progress
and if you want to subscribe to get automatic updates to your e-mail address you can go here:
https://www.hotrodreverend.com/blog-subscribe
Your personal information will be kept secure - this is a website built through Wix.com
thanks!
Daniel Jessup
Daniel Jessup
Here are some video links if you are interested.
https://vimeo.com/263944152
https://vimeo.com/263944328
https://vimeo.com/263953373
there is a bunch more over at hotrodreverend.com
Daniel Jessup
Daniel Jessup
Well, it's not a 100 percent done (speedo not hooked up, kickpanels not installed, no side view mirrors installed yet, etc) but I "slapped" things together because I promised my daughter I would take her to graduation in the Fairlane. Because of the timeline, all of the little tweaks such as carb tuning, distributor tuning, etc. were minimal at best. At least it was ready to STOP when needed (brakes bled, adjusted, checked a few times). It went out on several trips yesterday for a total of about 15 miles. Of course, as you guys know, the whole community was giving thumbs up, staring, waving, etc. Great times, and satisfying to get it back on the road. I was especially pleased with the transmission and suspension. Lowering the car with those Aerostar springs was a great idea - I only hit a bump stop once when I pulled into the driveway pretty quickly. On the road, pot holes included, all was fine. After Memorial Day I will post more but for now I thought some of you might like to see this....
Love the Y Block!
https://vimeo.com/271854558
Daniel Jessup
jsprengeler
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 3, Visits: 19.8K
Awesome Dan!!
Looks and sounds great. Nice work Dan.
Cliff
Posts: 908, Visits: 14.0K
NICE
