Carburetor
Posted By Kahuna 17 Years Ago
Kahuna
Posted 17 Years Ago
Posts: 471, Visits: 2.4K
Parts wanted-
I'm looking for a Ford?holley "Teapot" type four barrel carburetor, with these identifying numbers/letters: ECK-9510-C-xxxx.
Jim
Jckailua@aol.com
carl
Posted 17 Years Ago
Posts: 1.2K, Visits: 20.6K
Jim    The carb you need ECK. 9510-C LIST 1074 is for a 55 ford.i have one here with the manifold and might also have a spare,i will check tomorrow and let you know   Carl  Ohio
Kahuna
Posted 17 Years Ago
Thanks Carl, I really appreciate it
Jim
carl
Posted 17 Years Ago
Jim  The other carb i have is a ECK 9510 T. LIST 1074-1 It is a  55 Carb but not sure which motor or car or t bird it came on.i dont have any manuals that have that info. Carl   Ohio
Posted 17 Years Ago
Last Active: 4 hours ago
Posts: 3.7K, Visits: 322.6K
Jim, Carl:
Here's some carb applications:
ECK-C.......'55 T-Bird, std and Od
ECK-H.......'55 pass with 182 HP special or '55 T-Bird with  FOM
ECK-T.......'55 pass with 182 HP or '55 T-Bird no trans specified
Jim, the ECK-S on my truck we talked about on the phone is '55 Bird std and OD.
John in Selma, IN
DANIEL TINDER
Posted 17 Years Ago
Last Active: 1 hour ago
Posts: 1.7K, Visits: 149.9K
Jim,
If you need teapot for a driver, contact Pony Carburetors, Las Cruces, NM. They are pricey, but will likely have a good core with the correct list #. It will also run better than any home rebuild, since they have the process down pat.
6 VOLTS/POS. GRD. NW INDIANA
Kahuna
Posted 17 Years Ago
I want to thank everyone who responded. It was all very helpful. John, it was a pleasure chatting with you on the phone. I think I've got most of the things under control now.
Regards
Jim
carl
Posted 17 Years Ago
John  Thanks for the info. on the 55 carbs ,i will file it away for future use. Really like your heavy duty work bench  Carl   Ohio
rexbd
Posted 17 Years Ago
Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)
Posts: 128, Visits: 1.5K
looking for a T-pot for 55 tbird with FOM.  I found one on Craigs list but part number was ECK-9510-D.  any idea what that is for?
Posted 17 Years Ago
rexbd:
ECK-D is listed for '55 passenger with 182 HP special engine and FOM, AND---'55 T-Bird with FOM.
John in Selma, IN
