Carburetor
http://forums.y-blocksforever.com/Topic10540.aspx
By Kahuna - 17 Years Ago
Parts wanted-
I'm looking for a Ford?holley "Teapot" type four barrel carburetor, with these identifying numbers/letters: ECK-9510-C-xxxx.
Jim
Jckailua@aol.com
By carl - 17 Years Ago
Jim    The carb you need ECK. 9510-C LIST 1074 is for a 55 ford.i have one here with the manifold and might also have a spare,i will check tomorrow and let you know   Carl  Ohio
Thanks Carl, I really appreciate it
Jim
Jim  The other carb i have is a ECK 9510 T. LIST 1074-1 It is a  55 Carb but not sure which motor or car or t bird it came on.i dont have any manuals that have that info. Carl   Ohio
Jim, Carl:
Here's some carb applications:
ECK-C.......'55 T-Bird, std and Od
ECK-H.......'55 pass with 182 HP special or '55 T-Bird with  FOM
ECK-T.......'55 pass with 182 HP or '55 T-Bird no trans specified
Jim, the ECK-S on my truck we talked about on the phone is '55 Bird std and OD.
John in Selma, IN
By DANIEL TINDER - 17 Years Ago
Jim,
If you need teapot for a driver, contact Pony Carburetors, Las Cruces, NM. They are pricey, but will likely have a good core with the correct list #. It will also run better than any home rebuild, since they have the process down pat.
I want to thank everyone who responded. It was all very helpful. John, it was a pleasure chatting with you on the phone. I think I've got most of the things under control now.
Regards
Jim
John  Thanks for the info. on the 55 carbs ,i will file it away for future use. Really like your heavy duty work bench  Carl   Ohio
By rexbd - 17 Years Ago
looking for a T-pot for 55 tbird with FOM.  I found one on Craigs list but part number was ECK-9510-D.  any idea what that is for?
rexbd:
ECK-D is listed for '55 passenger with 182 HP special engine and FOM, AND---'55 T-Bird with FOM.
John in Selma, IN
