1962 292 RH exhaust manifold cracked...need one bad!
Posted By fallon 11 Years Ago
fallon
Problem Posted 11 Years Ago
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 3, Visits: 9
Hi all,
    After fabricating a new downpipe for the old dump, the inside ear of the RH manifold broke off and took part of the inside going up the manifold with it. After looking at the piece that broke off, it appears there was a crack in the casting as the top of the area broken off had a little rust all the way through whereas the sides that fresh broke had bright grey cast metal showing. I'm looking for anyone who might have one they'd be willing to part with. I have the single system with the cross over pipe that goes down the right side of the engine. Let me know so we can work out the logistics. Thanks.
Scott
Last Active: 5 hours ago
Posts: 3.7K, Visits: 323.2K
Is this a truck, and are you keeping the single exhaust system?  I may have one.
pintoplumber
Posts: 1.0K, Visits: 164.2K
I would have one also. I'm in PA.
I moved this to classifieds.
I may have one, too but I'm not sure where.  If one doesn't turn up, I'll look.  It must be in a box somewhere.
YBLOCKMERC
Last Active: 8 Months Ago
Posts: 194, Visits: 20.6K
I've got one with a good heat riser valve. Email is roadqwesty914@comcast.net
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
fallon
Posts: 3, Visits: 9
To all,
     Thanks for your responses for help with my dilemma. Someone is shipping me a replacement manifold. Hopefully with no hidden cracks. Now for brake line replacement and carb rebuild. Thanks again.
Scott
RayCarter18
Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)
Posts: 174, Visits: 1.7K
Are you still looking for the exhaust manifold? If so I have both manifolds of a 63 that I have replaced with duals. Manifolds are still good and has the exhaust valve in the manifold as well if you are interested email me raymondac23@yahoo.com
