1962 292 RH exhaust manifold cracked...need one bad!
Home
Keeping The Dream Alive!
Classifieds
http://forums.y-blocksforever.com/Topic104601.aspx
Print Topic
Close Window
By fallon
11 Years Ago
Hi all,
After fabricating a new downpipe for the old dump, the inside ear of the RH manifold broke off and took part of the inside going up the manifold with it. After looking at the piece that broke off, it appears there was a crack in the casting as the top of the area broken off had a little rust all the way through whereas the sides that fresh broke had bright grey cast metal showing. I'm looking for anyone who might have one they'd be willing to part with. I have the single system with the cross over pipe that goes down the right side of the engine. Let me know so we can work out the logistics. Thanks.
Scott
By Hoosier Hurricane
11 Years Ago
Is this a truck, and are you keeping the single exhaust system? I may have one.
By pintoplumber
11 Years Ago
I would have one also. I'm in PA.
By charliemccraney
11 Years Ago
I moved this to classifieds.
I may have one, too but I'm not sure where. If one doesn't turn up, I'll look. It must be in a box somewhere.
By YBLOCKMERC
11 Years Ago
I've got one with a good heat riser valve. Email is
roadqwesty914@comcast.net
By fallon
11 Years Ago
To all,
Thanks for your responses for help with my dilemma. Someone is shipping me a replacement manifold. Hopefully with no hidden cracks. Now for brake line replacement and carb rebuild. Thanks again.
Scott
By RayCarter18
11 Years Ago
Are you still looking for the exhaust manifold? If so I have both manifolds of a 63 that I have replaced with duals. Manifolds are still good and has the exhaust valve in the manifold as well if you are interested email me
raymondac23@yahoo.com
