My new pump does seem to be binding, certainly isn't smoothe. It does give good pressure when I manually wind it. Should I continue using it?
It would be an expensive fix because I'm down under.
Does the oil drain out of the pump if it is not used for a few weeks?
I filled the oil filter, and the rocker shafts.
Any ideas??
Kennny
