head bolts
Posted By unibody madness 11 Years Ago
unibody madness
Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)
Posts: 53, Visits: 1.7K
I am looking for two of the longer head bolts that go under the rockers. One of my heads came with them all the same size, a 1/4 inch shorter than the outer two are supposed to be.
John
YBLOCKMERC
Last Active: 6 Months Ago
Posts: 194, Visits: 20.6K
I think I've got those. I'll check tomorrow.
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
YBLOCKMERC
All the ones I have are either 5" or 2 1/2".
Marc
'54 Merc ragtop
Pt Townsend, WA
carl
Posts: 1.2K, Visits: 20.6K
unibody madness (5/5/2014)
John
John  If you have a Fastenal store close to you they have grade 8 bolts,I used them on my engine when it was rebuilt.If I remember right I had to cut a little off as they didn't have exactly the right length
Posts: 3.7K, Visits: 323.0K
John:
Keep in mind that the Fastenal bolts will have 5/8" hex heads, the originals have 11/16" hex.  Will require two different size sockets to torque the head.  I'm sure I have some used originals in my stash, let me know if you don't fine anything.
2721955meteor
Posts: 927, Visits: 190.0K
i just went to a cat dealer for 4 of the longer 1s,they ar grade 8 and 1/4 longer. cliff
unibody madness
Thanks guys. after I torqued the right side with the correct bolts, the left side felt sketchy with only the shorter bolt in all five holes
unibody madness
Still looking for those bolts
Give me your mailing address and I'll send you a couple.  They are used ones.
