head bolts
http://forums.y-blocksforever.com/Topic104170.aspx
By unibody madness - 12 Years Ago
I am looking for two of the longer head bolts that go under the rockers. One of my heads came with them all the same size, a 1/4 inch shorter than the outer two are supposed to be.
John
By YBLOCKMERC - 12 Years Ago
I think I've got those. I'll check tomorrow.
All the ones I have are either 5" or 2 1/2".
By carl - 12 Years Ago
unibody madness (5/5/2014)
John
John  If you have a Fastenal store close to you they have grade 8 bolts,I used them on my engine when it was rebuilt.If I remember right I had to cut a little off as they didn't have exactly the right length
John:
Keep in mind that the Fastenal bolts will have 5/8" hex heads, the originals have 11/16" hex.  Will require two different size sockets to torque the head.  I'm sure I have some used originals in my stash, let me know if you don't fine anything.
By 2721955meteor - 12 Years Ago
i just went to a cat dealer for 4 of the longer 1s,they ar grade 8 and 1/4 longer. cliff
Thanks guys. after I torqued the right side with the correct bolts, the left side felt sketchy with only the shorter bolt in all five holes
Still looking for those bolts
Give me your mailing address and I'll send you a couple.  They are used ones.
