looking for a good, used compression tester... suggestions...??
Posted By texasmark1 11 Years Ago
texasmark1
Posts: 650, Visits: 2.7K
the title/subject pretty much says it all.
many of these on epay and such...
any particular brand/style/type that comes recommended?
for use on my 57 Fairlane and Daniel's 63 Merc...
plus, it will go to Daniel someday, as I am already planning on his needs for car stuff after my use for them ends.
thanks,Mark
Posts: 6.1K, Visits: 442.9K
Since it is something you will hand down, why not get new?
Made in USA:
http://gsiindustries.com/cgi-bin/Search/data.pl?group=d&order_by=id&order=123&method=perfect
Mine is an old Sears or Craftsman, Made in USA, but I had GSI make a hose for it which uses a quick disconnect fitting right at the plug hole which makes the use of the tester much easier for some applications.  I think the same sort of thing is included with their #6500 compression tester.
Posts: 4.6K, Visits: 38.4K
You will probably not use the tester often so I would go with someone like Harbor Freight. Cheap but functional for the home user. Chuck
texasmark1
OK... shamed into spending $23 for a new kit from Harbor Freight...
instructions say remove all plugs the test... I thought one at a time was the way to do it...??
Take out all the plugs and tie the carb wide open. Removes any additional drag on the engine. Chuck
texasmark1
thanks!
