9 inch rearend
Posted By Cactus 18 Years Ago
Cactus
Posted 18 Years Ago
Posts: 229, Visits: 30.2K
What would be a good place or vehicle to find a nine inch that I can put in my '56 customline?
Jan  Urbanczyk  Major USMC Ret.
        Bowie Maryland
Tom Compton
Posted 18 Years Ago
Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)
Posts: 287, Visits: 4.0K
57, 58, and 59 ford cars.  Lincoln Versailles (already has disc brakes), some Granadas and Monarchs.
You gotta have the right tools and know how to use 'em.
TC - Austin, Texas
Cactus
Posted 18 Years Ago
Thanks, Tom.  I always like to talk to fellow Texans.
        Bowie Maryland
Posted 18 Years Ago
Cactus,
          If you're running an automatic, and only on the street, you can also use an 8' from an early 60's Mustang or Fairlane. They're fairly strong and generally cheaper. But you'll have to convinve most owners that they are NOT a nine inch and not worth $200,000!BigGrin
Cactus
Posted 18 Years Ago
I am running a moderately breathed on 317" motor with a T-5, and I am just a little concerned with the durability of the stock rearend.
        Bowie Maryland
Posted 18 Years Ago
Jan,
        A well set up 8" will easily handle 300 hp. Late model 8.8's in the Fox bodies are common and inexpensive also. You'd need to remove the control arms and brackets and weld on some leaf spring brackets, but that's not impossible. If you use a 57 58 or 9 rear end, you might want to replace the pumpkin with a later big bearing unit. the '57 parts were not very strong.
yehaabill
Posted 18 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Catus Y-Guy   You might try looking at Explorer rear ends. I just pulled
                     two from"Pull-A_Part" junkyard. They are 53" from B.P.
                     to B.P. and already have leaf perches plus you can get
                     ratio's from 3.08,3.55,3.73 and 4.10. When you look at
                     the rear end tag, If there is an "L" between the numbers
                     (example 3L73) then its a posi-unit. You can get these
                      for 65-85$$ with drums or disc w/caliphers!!! The 8.8
                      is plenty tough for our Y's and they are lighter plus
                       90% will be 31 spline.... Thx Bill
Bill
Pelham,Al
Posted 18 Years Ago
Last Active: 42 minutes ago
Posts: 4.6K, Visits: 39.3K
Problem with explorers they are usually 5 on 5.5" bolt patterns. You can buy replacement axles with a 5 on 4.5" but they are a couple hundred dollars. Chuck in NH
yehaabill
Posted 18 Years Ago
Y-Guys All explorer's are 5 on 41/2, same as rangers.
Thx Bill
Bill
Pelham,Al
Cactus
Posted 18 Years Ago
Thanks all, for the responses.  I guess I had better go to a local U-Pik-it, (Called Crazy Ray's) here in Maryland to look for some explorers.
        Bowie Maryland
