9 inch rearend
http://forums.y-blocksforever.com/Topic10043.aspx
By Cactus - 18 Years Ago
What would be a good place or vehicle to find a nine inch that I can put in my '56 customline?
By Tom Compton - 18 Years Ago
57, 58, and 59 ford cars.  Lincoln Versailles (already has disc brakes), some Granadas and Monarchs.
Thanks, Tom.  I always like to talk to fellow Texans.
By pegleg - 18 Years Ago
Cactus,
          If you're running an automatic, and only on the street, you can also use an 8' from an early 60's Mustang or Fairlane. They're fairly strong and generally cheaper. But you'll have to convinve most owners that they are NOT a nine inch and not worth $200,000!BigGrin
I am running a moderately breathed on 317" motor with a T-5, and I am just a little concerned with the durability of the stock rearend.
Jan,
        A well set up 8" will easily handle 300 hp. Late model 8.8's in the Fox bodies are common and inexpensive also. You'd need to remove the control arms and brackets and weld on some leaf spring brackets, but that's not impossible. If you use a 57 58 or 9 rear end, you might want to replace the pumpkin with a later big bearing unit. the '57 parts were not very strong.
By yehaabill - 18 Years Ago
Catus Y-Guy   You might try looking at Explorer rear ends. I just pulled
                     two from"Pull-A_Part" junkyard. They are 53" from B.P.
                     to B.P. and already have leaf perches plus you can get
                     ratio's from 3.08,3.55,3.73 and 4.10. When you look at
                     the rear end tag, If there is an "L" between the numbers
                     (example 3L73) then its a posi-unit. You can get these
                      for 65-85$$ with drums or disc w/caliphers!!! The 8.8
                      is plenty tough for our Y's and they are lighter plus
                       90% will be 31 spline.... Thx Bill
By MoonShadow - 18 Years Ago
Problem with explorers they are usually 5 on 5.5" bolt patterns. You can buy replacement axles with a 5 on 4.5" but they are a couple hundred dollars. Chuck in NH
Y-Guys All explorer's are 5 on 41/2, same as rangers.
Thx Bill
Thanks all, for the responses.  I guess I had better go to a local U-Pik-it, (Called Crazy Ray's) here in Maryland to look for some explorers.
Forgot about the Explorer...DUH!w00t Take a tape measure, think they're pretty close to your car. IF it has disc brakes you may want to grab the proportioning valve and I don't think youe oe wheels will clear the calipers.
Where I said Explorer please insert Bronco! DUH DUH! Wink Chuck in NH
Don't overlook the Rangers.
Yeah, I have the right tools around here somewhere if I could just find them again!Smile Chuck in NH
PS: I did come up with a Cougar 9" for mine but will leave the stocker (3:80 posi) in until it breaks.
