OIL
http://forums.y-blocksforever.com/Topic160040.aspx
By Bobby O 55 - 3 Years Ago
Hi Guys. What is everyone using for oil. I've been using Shell Rotella 15-40. Getting tough to get now. Coming thru w/synthetic blend. Is this OK. Are there any other brands you guys use. Thank you.
By Cliff - 3 Years Ago
Check this out     https://540ratblog.wordpress.com/
By Ted - 3 Years Ago
In addition to the link that Cliff provided, here are just a few of the links to threads available on this site regarding oil for the Ford Y.
Break in oil
General discussion 1
General discussion 2
General discussion 3
Gil Baumgartner oil study
Multi-viscosity oil clarification
Why to not use diesel oil in a gasoline engine
ZDDP
By Deyomatic - 3 Years Ago
Wow...that 540ratblog is a veritable rabbit hole.  Helped me change my mind about the gear oil I planned on running, though.
Lucas 10-30 Hot Rod oil. Stays close to the 20-20w Henry recommended on the glove box sticker. Nice flow from the rocker arm shafts when warm.
By Florida_Phil - 3 Years Ago
Valvoline VR-1 10W-30.  No additives needed.
http://forums.y-blocksforever.com/uploads/images/7f5b9531-801f-4c10-b544-6afc.jpg
By 312YBlock - 3 Years Ago
Here’s what I use, It’s a high zinc formula for flat tappet engines.
Valvoline 20W-50 VR1 Racing Oil part #vv211 or NAPA VAL822347
It comes in a six pack.
By paul2748 - 3 Years Ago
Ted has always said diesel oil is not the best for a gas (especially a Y) engine.  I go with what he uses - Valvoline conventional 10-40.
As stated in the article,  ZDDP is not the best measure of a good oil.  And to much can cause increased wear
