Visits: 1.9K
has anyone installed a brighter 1157 led bulb on their turnsignal and taillights without any modifications on a 1956 Fairlane?
Posts: 3.6K,
Visits: 497.5K
I haven't, but you must use a special flasher with the signal lights.
54 Victoria 312; 48 Ford Conv 302, 56 Bird 312 Forever Ford Midland Park, NJ
Last Active: 32 minutes ago
Posts: 4.6K,
Visits: 37.7K
There is a special flasher for the LED's or heavy duty. I tried to convert to full LED but had a lot of problems with them working intermittently. I did find a set of brighter 1157 bulbs that have never given me a problem. Some say the old wiring has a problem with the low voltage of the LED.
Y's guys rule! Looking for McCullouch VS57 brackets and parts. Also looking for 28 Chrysler series 72 parts. And early Hemi parts.
  MoonShadow, 292 w/McCulloch, 28 Chrysler Roadster, 354 Hemi) Manchester, New Hampshire
Visits: 2.5K
I installed Sylvania Zevo 1157 bulbs only on the taillights of my 56 F100 without any flasher or wiring modification.
Posts: 1.7K,
Visits: 340.0K
I’ve tried a few different bulbs even LEDs and went back to Sylvania’s. The 56 has one of the best/brightest taillights of the era by far including the circular reflector. In FOMOCO Times a person made a kit to add our above backup light reflector to a stop/turn and I decided to get them but he had quit so I made my own for $10. That little extra may help. I changed the back up lamps to a “whiter” bulb that really helped. Been trying to find the same style for the interior but so far not found one. I also use Halogen seal beams which are “whiter” in the front... Good luck.
Visits: 190.0K
i use led turn signals front and rear,had to install 2 cheap reg clearance lights 1 for each side, i put them under the hood, low and behold don't need the special expensive flasher. this has worked for 2 years,the load is enough to activate the old 12volt flasher
Posts: 3.6K,
Visits: 497.5K
I got some led 's for the dash of my 54. Amazing difference. # BA9S - 4 led's around the perimeter and one on top. Got on ebay. Try this number 154014009988. Direct plug in
