Identifying a TBird Differential
Posted By CK and his 55Tbird 12 Years Ago
yblock
Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)Supercharged (143 reputation)
Posts: 57, Visits: 189
Ford 9in rear axels. googal ford 9in rear axels,the site has all the info you will ever need. they say 57-59 ranchero and 65-67 mustang hps ar the same width 57,25. giv it a try,ther ar other sources listed. cliff 57ranchero
CK and his 55Tbird
Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)
Posts: 104, Visits: 273
I was at the Ballarat swap meet today and I saw one the same and they said it was a zepher diff. And some of these were found in ford cars to.
nearly bought a 9", yet many other goodies.
CK and his 55Tbird
I also found a what I think is a Dana 44 which was out of a Mainline ute. I can get it for $75, Should I buy it and keep as spare? or fit as runner?He thinks it may be a 3.5:1 ratio.
slick56
Posts: 463, Visits: 4.5K
All Aussie Mainline utes were 4.11:1 as far as i know.
Strong diff, aussie drag racers used to use them before 9"ers became available.
I have a 3.55:1 out of a 53 sedan delivery in my 52 Mainline with 302w and AOD.
South Australia
aussiebill
Posts: 1.8K, Visits: 11.4K
CK and his 55Tbird (2/23/2014)
Manual OHV mainlines, 4.09 ; 1, Auto mainlines 3;54. The 4.09 is usually stamped on RH diff tube looking from the rear. The 3.54 is usually stamped on cast web running to tube area. Allow variances for my fadeing memory.
 Down Under, Australia
CK and his 55Tbird
He mentioned it may have been a 3.55:1I think for $75 I should just buy it. I will check the tubes and casting to see.
So it is a DANA 44 ?
lyonroad
Posts: 703, Visits: 3.1K
Dana 44,
Does it look like this?
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
CK and his 55Tbird
Yep
Frankenstein57
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
The Lincoln Versailes disc brake rear end has the same width, center pin to center pin, as my 57 and 58 rancheros. Not sure what the t-bird width is, hope this helps
thanks, Mark
CK and his 55Tbird
So the diff in the bird at the moment looks to be a shoebox 49-51 merc??The axles are a 17 spline, yet thick shaft similar to 28 spline 9" ????
