MSD Distributor
Posted By kidcourier 17 Years Ago
kidcourier
Posted 17 Years Ago
Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)
Posts: 127, Visits: 8.8K
   Just installed a MSD -Plug and Play distributor #8383 on my 57 Courier and with the install directions comes a warning that you may have to modify to get it to fit,they're right! only choices I could see were either unbolt the engine and trans and move them forward 1" to 2" to drop it in and bolt it all back up or cut the lip on the firewall back flush with the firewall to let it slip in.now I'm going to have to figure out how to dress up the lip--cut the rest of the lip out and weld the seam and smooth it out or use some small vacuum hose or plastic wire cover to cover it so you won't notice to the unknowing eye. Those thinking of a points change may want to go with the Petronix module kit in your stock distributor or supposedly they brought out a distributor for the Y-block,if so you might want to check the overall size and length to your stock one! SKIP
Posted 17 Years Ago
Suede 57 did an article on this a couple years ago for the old forum. He did the firewall thing.
I think there's a link on this forum to his report.
GREENBIRD56
Posted 17 Years Ago
Posts: 1.7K, Visits: 102.7K
This is a modified Y-block Ford distributor with Duraspark II trigger mechanism (which is the same stator / reluctor trigger used by MSD). Look at the 331 cid dyno report on Mummert's site - it will support plenty of horses.
With an MSD trigger lead, 6A "Red box", and a curve kit - I think this outfit will fit all of the 50's firewalls without too much trouble.
Pete's Panel
Posted 17 Years Ago
Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)
Posts: 129, Visits: 958
Is there the same firewall problems for the MSD distributors in 57-60 F100's?
Pete, one of the Aussie mob.Hehe Beechworth, Victoria60 F100 Panel Van, Y-block. 65 Galaxie Country Sedan 390
Bigwin56F100
Posted 17 Years Ago
Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)
Last Active: 9 Months Ago
Posts: 100, Visits: 755
Pete,
They fit the 56 f100's as Im running one of the 8383's in my truck. I had plenty of room during and after install.
Kevin Bigwin
Kevin S in Akron, Ohio
Posted 17 Years Ago
It helps him cut good starting line lights too!
Unibodyguy
Posted 17 Years Ago
Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)
Posts: 240, Visits: 848
I know in the last issue of Custom Classic Trucks,(Feb.08) John Gilbert installed one on his 56 F100. I'd like to see if there was any horsepower difference by adding a MSD. I'm not quite sure what John had originally in the truck before the changeover and how much better it worked.
                          Michael
Michael
Sandy Valley, NV
Bigwin56F100
Posted 17 Years Ago
My performance didnt really change much. I did it as I wanted a full mechanical dist with no vac advance. It would probably run better if I had the 6A box. I was able to run the rpm's up further than the 57 point dist.
Kevin Bigwin
yehaabill
Posted 17 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Steve The duraspark/relucter(sp?) deal in the dist. picture, are these
         ford parts? Ford part numbers? How to install or is their a thread
         on this somewhere?    Thanks Bill
Bill
Pelham,Al
Posted 17 Years Ago
Last Active: 27 minutes ago
Posts: 4.6K, Visits: 38.5K
Check out this info in the Tech area. Gives a breakdown on the whole deal. Chuck in NH
http://www.y-blocksforever.com/tech/html/loadomatic.html
