Last Active: 4 Months Ago
Visits: 234
I wold like to buy a 1955 Ford Fairlaine Brake Pedal Assembly.
Last Active: 6 days ago
Visits: 20.6K
raybaker1 (12/18/2013) I wold like to buy a 1955 Ford Fairlaine Brake Pedal Assembly. not sure by what you mean by assembly,do you need everything that hangs under the dash. Carl
Visits: 234
I need the brake pedal which attaches to the bracket that bolts to the car and firewall This bracket is held in place partially by the bolts and nuts that come in though the firewall from the master cylinder. This assembly should also have a bracket where the brake switch attaches to.
Thank,
Ray
Visits: 3.1K
Isn't the brake light switch on the brake line? If the rod/bar from the brake pedal to the master cylinder has a square end you can modify the attchment to accept a late model ford brake light switch and do away with the inline switch.
Mark
