Visits: 333
I found one lastnite while i was looking around the forums. Sounds like thats the way i'm going to go i've never had trouble with a duraspark system
1962 f250 currently heartless 1961 country squire 292 3 speed 1963 galaxie 390 powered 1976 f250 4wd 390 powered
Posts: 1.6K,
Visits: 5.2K
Check with Ted on Harland Sharp rockers, I think they have had better luck with them!
Visits: 333
Ok thanks for the tip. I have harland sharps on my 390 and have not had any trouble with them as long as you dont try to use the old umbrella seals. Car wasnt hard to find at least when it was running !
Visits: 333
Whats are you guys using for valve spring locks and retainers? I just got my new valves and i'm looking to send my heads to the machine shop was just curious if stock is ok or if i should upgrade? Thanks
Visits: 323.8K
I use 429/460 retainers with the stock Y keepers. 289/early 302 retainers also will work. Both are single piece retainers. They are not machined for dual valve springs, but single springs with or without dampers are OK.
Visits: 333
Ok thanks i'll get some 460 retainers.
Visits: 333
Update to what's happening with my old truck, she's been successfully converted to 4wd. I used a 73 f250 for its axles and running gear. Sadly the trucks not y block powered but is 360 fe powered. She's been on the road for the last 6 weeks enjoying the road again for the first time since the 90s
