Rebelliousengineering®
Visits: 176
So currently my 57 fairlane 500 292 is running dual glass packs and there to me to quiet so when my engine gets rebuilt I was thinking of using some magnaflows I would use flow masters but I don't really want that resonance noise in my car because I really like my music and it being crisp with out interference but I still love that rumbling sound. So I’m trying to see if anyone is running maganflows and if you are do like them or is there any other set up that you guys like better.
Not my dads 57 Fairlane nor my grandfathers, young guns are taking over ! REBELLIOUSENGINEERING.COM
Visits: 442.8K
Which glass packs are currently installed? I was using Flowtech Purple Hornies for a while. Those were loud. Maybe you just need the right glass packs. I'm presently using Hooker Aerochamber mufflers. They have about the same noise level as the glass packs at idle but they are quieter everywhere else and sound pretty good, in my opinion. They are still noisy but quiet enough that I will not get any unwanted attention. At first, I noticed resonance at idle. It either isn't doing it anymore or I got used to it. I've only heard good things about Magnaflow but I've no personal experience with them.
yehaabill
Visits: 1.4K
Y-Guy I've got the magnaflow's on my '60 F100/292/Reds headers. They are not loud until you twist-it over 3500rpm. (Still not anywhere near as loud as a glasspack) Mine are both out the right side ,so out the back could make a diference... See Ya Bill
Bill Pelham,Al
Marc
Visits: 5.3K
I've been running smitty's for a while, I think almost 10 years. Nice rumble around town, good 'n loud when you put your foot in it.
Posts: 3.0K,
Visits: 8.7K
Flowmaster three chambers with 2 1/2 inch pipes and a x style crossover, Radio works fine,
Visits: 176
Thanks for all the responses I don't know what glass packs I have there all rusty, but defiantly not loud at all I’ve tried driving the car to heat up the glass pack and throwing in cold water to try to break up the glass webbing and that didn’t do anything besides clean all the black carbon deposit so will see what I go with, but I’ll keep you all posted when I change it all out.
Moz
Visits: 3.7K
hey frank dont tell me that when your blasting down the drag strip your listening to the radio
 moz. geelong victoria australia. graduate 1980, bus, truck, car, hot rod, boat, submarine, hovercraft, hydrafoil, firetruck, mobile home, jet, helicopter, cruise ship, motorcycle, bicycle, santa's sleigh, clock, alloy bullbar, alloy fuel tank, lens, dr who's tardis, matter - anti matter warp drive buffer & y-block lover
63 Red Stake Bed
Last Active: 14 Years Ago
Visits: 594
I used turbo tubes, & lopped off the offset inlet & outlets. I then found a pipe that would fit perfectly w/it's od inside the tubes. I then slid it up, past the 1st noise chambers. I flared it out to accept the 2 1/2 I used. Idle is a bit more melow than a glass pack. Off idle is in line w/ a typical cherry bomb. From about 2300 up, it cakels like a cross between a worn glasspack & a straight pipe. I think they started out as about 18" long, effectively they have about 13" of area for noise reduction. What I like most is they do not have the back rap sound that most glasspack systems have. I don't even have a crossover, still no back rap.
Posts: 3.0K,
Visits: 8.7K
Moz, Depends on what's on the radio. I do best with some good mellow Jazz. Basie, Brubeck, Paul Desmond, Feistritzer makes me turn it off in the tow truck.
Moz
Visits: 3.7K
frank doesnt john like music how much music do you hear in 14sec about 2 bars. hows the weather at your side of the world.
