Posts: 7.5K,
Visits: 205.8K
zuburg (5/6/2016) What kind of glue should I use? I don’t use glue with the fiber oil filter plate gaskets. If I did use any kind of sealer, it would likely be CopperCoat®. I make it a point to insure that the oil filter plate is not deformed to the point that it will not hold pressure against the gasket. When that deformation is evident, then I simply put the plate in a press and reform it so that it will hold tension against the gasket.
