Putting on a oil filter adapter on my 1955
http://forums.y-blocksforever.com/Topic92605.aspx
By timmy4 - 12 Years Ago
I decided to remove the cartridge oil filter and putting on a spin on oil filter adapter and I know it is a messy job. AAfter I glue the gasket to the filter adapter how tight should I put the nut that goes in to the block that holds the adapter on thanks
By ericsligar - 12 Years Ago
I would think you'd torque to factory specs, which is pretty high (I'm wanting to say north of 40 lbs). If you have shop manual it will be at the end of the book. If not I'll look it up when I get home. I don't know if the adaptor uses the same, or a similar, bolt as the stock filter plate does. If so it's pretty shallow and tough to get hold of. I had to grind a six-point socket down flat to get rid of the bevel, otherwise it wouldn't grab the bolt head. You're probably going to need to do it this way to get the factory bold out. I used a cheater bar as well after I struggle with it for 20 minutes.
By 312T85Bird - 12 Years Ago
What type of gasket are you using? The original was a paper product and required a thin coat of oil upon installaton where the replacement is not a paper product and should be put in dry! Glue?????? Looking for a leak thet can be later blamed on the rear main??
312T85Bird
If you can get a hold of a 3/4" set of sockets the correct sizt socket will work without grinding down one from a 1/2" set.
312T85Bird
I changed the gasket on the stock filter plate last year. Pain in the butt. The gasket that came with the canister filter is now rubber. I'm going to swap my set up as well as soon as I get through the two other filters I bought. It took a while to find them and to get them in, so I bought ahead. Last time I do that. I only put 500 miles on that car a year probably!
By Talkwrench - 12 Years Ago
It will have to be fairly tight. Yup glue that O ring on the plate make sure everything is clean and away you go, take your time and all should be well. Remember you will be spinning a new filter on and off it.
I took the cartridge filter off and where the housing mated to the block there is a plate with a nut holding it on. Does that have to come off then put the oil filter adapter where the plate is thanks
yes
312T85Bird
By zuburg - 9 Years Ago
What kind of glue should I use?
I sprayed the gasket with copper coat one side. I did not buy a replacement kit I heard the leaked so I found an original. Never has leaked.
By Ted - 9 Years Ago
zuburg (5/6/2016)
I don’t use glue with the fiber oil filter plate gaskets.  If I did use any kind of sealer, it would likely be CopperCoat®.  I make it a point to insure that the oil filter plate is not deformed to the point that it will not hold pressure against the gasket.  When that deformation is evident, then I simply put the plate in a press and reform it so that it will hold tension against the gasket.
