Posts: 7.5K,
Visits: 205.8K
56 ford custom (11/1/2013) Pf Arcand, is the 573 still being made or do I need to score a used one?The 573's as well as any other 3X2 intakes for the Y haven't been available 'new' for a good number of years now. Used it is.. Here is the link to the thread showing the low end torque values for the various 3X2 intakes. The small runner intakes do make for better everyday drivers at the expense of some upper rpm horsepower. .http://forums.y-blocksforever.com/FindPost40720.aspx
Visits: 1.0K
Ted, I think the only reason why I was worried about not using the 553 is because of the rear bellcrank mount for the early 2v style. Now that it has been clarified that I can use the later style fir 4v and just alter the shafts..well I guess that means I can run the 573 and no issues I suppose
Fomoco Low Life
Visits: 1.0K
Alright fellas I ripped through all of my stash and found all of this. What parts do I need? There are two different styles of firewall/throttke linkage, which is correct?
Fomoco Low Life
Visits: 3.9K
Folks, I know that this is OLD; but, it was the only reference I could find for my question: I've a ECZ-B manifold on the engine in my '55 Crown and can't find the throttle bellcrank part that mounts to the manifold.
Can anyone point me to drawings, part numbers, suppliers, etc., for me to obtain one. It's the angular-looking two-hole bracket that bolts toward the rear driver's side on top of the intake manifold. It shows in the first photo in this post.
Thanks, JLB
Visits: 3.9K
P. S: It's the bracket at the very bottom of the LAST photo posted. JLB
Last Active: 6 days ago
Visits: 32.6K
bergmanj (10/28/2018)
P. S: It's the bracket at the very bottom of the LAST photo posted. JLB Check out Ebay Item # 263961320872. I think that is for Automatic Transmission. Also a NOS One 222321995464.
Visits: 285.6K
Does anyone know if a 3/2 setup with fit under the hood of a 1955 Thunderbird?
Posts: 1.8K,
Visits: 306.3K
Visits: 32.6K
If You go further into His Information He builds various multi-Carb Setups and then sells them. I think its a "Hobby" for Him. He has sold some very nice Setups. All seem to be $1500.00 USD delivered anywhere in N. America. I have seen His Items on Ebay once in awhile. I don't know where He finds the Various Intakes for these multi Carb Installations. Nice workmanship on all of them.
Posts: 1.9K,
Visits: 194.9K
Phil, years ago I had on Offy manifold on my 55 bird. IIRC, I had to cut the rear element down about a 1/4 inch for hood clearance. I was using a little louvered air cleaner, but probably the same element size as the picture K posted. Ford 94 carbs. I could have milled the rear flange down, but I got away with the cheap fix.
