1956 ford with 292/fordo usinf stock throttle/trans linkages with 3x2?
Posted By 56 ford custom 12 Years Ago
1956 ford with 292/fordo usinf stock throttle/trans linkages with 3x2?...
skygazer
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
skygazer (10/29/2013)
... I believe that the '63 M-code 390 FE t-bird 3x2 had "vacuum secondaries" as well.
I may be wrong. This thread indicates that only Mercury '58 tripowers had vacuum secondaries, and all of the FE tripowers were mechanical.
So, anyone have experience with a tripower on a y-block with a fordomatic?
56 ford custom
Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)Supercharged (318 reputation)
Posts: 217, Visits: 1.0K
I havent really seen anyone run a 3x2 with a fordo. This is what I'm trying to find out since this is what I will run on my car
Fomoco Low Life
skygazer
I've considered a tripower as well. I'm worried that with a fordomatic, the engine will bog horribly when I floor the throttle... at least until the transmission downshifts.
Mercurys, Oldses, Vettes, Pontiacs and MOPARs all had tripowers (or "6 packs") with vacuum secondaries, at least at some point in time.
Then again if the FE birds (all automatics, AFIK) with tripowers had mechanical linkages, perhaps it's not so bad...
56 ford custom
Thats the thing.....If those big blocks had tri powers and autos that didnt bog im sure it will be fine. Just need to be adjusted correctly
Fomoco Low Life
Daniel Jessup
Last Active: 9 hours ago
Posts: 2.0K, Visits: 131.0K
If you are using the 2 barrels like the 94's (ECG and EBU style) from the mid-fifties then I would think to get "vacuum secondaries" (meaning that the two end carbs only come in when engine vacuum demands it) you are going to have to rig up some type of a wild triple carb linkage setup that I have never laid eyes on. I am positive that the 58 Merc would have used those 2300 style 2 barrel carbs... A MUCH DIFFERENT ANIMAL than the mid-fifties 3 bolt flange carbs, so I have no idea if that linkage assembly would work.
I have seen plenty of 3 deuce setups on a 55 or 56 that run an original Fordomatic transmission. However, the ones I have seen use the 2 barrel bellcrank that attaches to the two hole bosses that are almost directly in line with the carb as you look at it from the center. The bellcrank in your original photo is one that is used "offset" of the carburetor and to the driver's side. The teapot carbs and almost all 4 barrels are actuated this way.
EDIT:
Take a look at the following photo of Speedway's 3 deuce linkage. If you run 94's this is what you need...
http://forums.y-blocksforever.com/Uploads/Images/18cff11c-96ec-4c50-bbbd-1500.jpg
It can be hooked up as progressive or all out with the butterfly shafts. They actually took this photo with the center pivot down instead of up like it is supposed to be so the pivot holes would just about line up all the way through three carbs.
Daniel Jessup
Lancaster, California
56 ford custom
So you are saying if I find an original 2bbla bellcrank it should work just fine?
Fomoco Low Life
56 ford custom
Yeah it definitely has to be progressive linkage. I found the whole set up like I said but its from a v8 4bbl fordo car. I would like to know what all from the linkages are the same from the 4 and 2 barrel carbs?
Fomoco Low Life
Last Active: 4 hours ago
Posts: 4.6K, Visits: 38.5K
I havn't set up a 3 deuce for a long time but can't you use the stock bellcrank with a rod to the center carb? If the carb linkage setup is on the passenger side wouldn't the stock 2bbl unit work? Chuck
The Master Cylinder
Posts: 974, Visits: 6.2K
MoonShadow (10/30/2013)
Chuck, you are correct. Problem is the OP want to use the Four barrel bell crank. Don't think it will work since the rod is on the drivers side of the carb. Already mentioned that a few post back.
I have extended throttle shafts on my 97's so everything mounted on the drivers side. You might be able to use the four barrel bell crank if you do that. I can't say for sure. I use a Lokar Cable. Also use a Lokar Cable on the kickdown for my C-4.
56 ford custom
Well I wouldn't mind using the 2bbl set uo if I can find one. Any leads?
Fomoco Low Life
