Visits: 1.7K
Looking for a truck three speed bell for my y block t5 conversion.
Posts: 7.4K,
Visits: 205.7K
Where are you located?
Visits: 1.7K
Sorry, I am located in California,94591.
Ted, this will be going on the Y you helped me figure out displacement with back when I joined.
It will be going into a 38 ford pu I'm starting when I retire. I do not want to modify it, I am going to try John Mummerts adapter plate ,so I don't want to use up one of his. I have two adapted bells from John on 61 trucks one behind a Y, and one behind a 223
John
Visits: 1.8K
I see them on EPay pretty regularly... consistently selling between $65-$75, plus the ride... you could also check with JM, as he is also a source for modifying the bolt pattern to accept the T-5. Cheers... Brian
Cylinder Index = 84Current Experiment = `57 Tbird, Grand Rapids, Michigan
