Visits: 506
Looking for the 9/16 fine thread bolts for the F 100 truck rear mounts that go through the ears on the bell housing.
Posts: 3.6K,
Visits: 497.6K
HARDWARE STORE?
Visits: 506
Been there and to a specially fastener store problem is not enough bearing shank surface and too many threads the original bolts have a longer bearing length for the sleve to ride in and shorter threaded length I can buy longer bolts and cut off a bit of the threaded part just testing the water to see if any one has a set of usable ones befor I have to cut to length longer bolts.
Visits: 318
Most Hardware Stores Will Not Carry Grade 8 Bolts, depending on where you are try Fastenall as they will have Grade 8's
312T85Bird
What?
