Visits: 15
Thanks to everyone! Will watch it, know a guy who might be able to get it "dialed" for me
Last Active: 9 hours ago
Visits: 206.1K
Resto_1 (10/4/2013) What would be the diff between the HD truck and the T-bird pieces? thanks,While the truck distributors with tachometer drives seem to be available in at least a couple of different styles, they have all been using iron for the main body material instead of aluminum as used on the Thunderbird distributors. The ebay unit that’s pictured is a one piece design but I’ve come across some taller units that incorporate a two piece design around the points housing.
Visits: 498.3K
Since the truck is not going to be strictly stock, look at aftermarket electric tach's that will fit the hole.
Visits: 15
Thanks for the suggestion, however using the HD instrument panel with n OE factory air pressure gauge and being able to us the a OE tach is the whole point of this exercise.
Posts: 1.4K,
Visits: 179.6K
The same eBay seller of the distributor has the tach that goes with the distributor up for auction.
See eBay item number 161121147573
Regards,
Visits: 15
Yep, got'er on my watch list. Thanks!
Visits: 15
The ebay ad shows 292 or 331. I emailed the guy, it's out of a 331. But, found another one
Last Active: 6 Months Ago
Visits: 8.4K
What is a 331, and what did it come in?
Visits: 15
I believe it's an FE motor
Visits: 8.4K
FE were 332 & 352 to start with.
