Visits: 12.3K
Original rear end drum to drum with 4:30 gears $200. Stock drive shaft 27 inch joint to joint $75. Bullet proof drive shaft 28 1/4 joint to joint $150. Six blade chrome fan $85. Shafer light weight clutch pressure plate and flywheel $125. Full syncro 3 speed transmission (syncro'd in first) $150. Mallory tach drive distributor $150. Spalding Flamethrower tach drive distributor $500. 4 G posted heads $100 ea 1 non posted G head $75. Set of 1:54 rockers $100. Ford 9 inch 28 spline traction loc unit $150. Let me know on the heavy stuff or I won't be bringing them to Columbus.
Vic Correnti
Visits: 39.4K
Hey Vic I'll take the Trac Lock if you bring it. Chuck
Visits: 12.3K
Chuck, it's yours.
Vic Correnti
Visits: 12.3K
Oops Senior moment, I went to put it into the trailer and the box said it is a 31 spine not 28. Do you still want it?
Vic Correnti
Visits: 39.4K
Yup! I have a few 9" rears of both splines. Should be plenty strong for street use. Chuck
