53-55 Ford truck fuel tank fit 56
Posted By 55 pick-up 13 Years Ago
55 pick-up
Posted 13 Years Ago
Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)Supercharged (155 reputation)
Posts: 29, Visits: 1.8K
Did anyone try to install a 53-55 fuel tank in a 56 truck-- get ride of tank behind seat and like the 53-55 fuel tank and fill locations and is SAFE behind frame----- any pictures finish product---Thanks
John Mummert
Posted 13 Years Ago
Last Active: 6 days ago
Posts: 918, Visits: 7.5K
You will need the 53-55 running board mounts for the drivers side. The early mounts have a sharp bend to clear the tank. The 56 mounts are curved in a larger radius. I can't tell you for certain that the early mounts will bolt to the 56 frame but as far as I know the running boards are the same so the spacing must be the same.
http://ford-y-block.com
2721955meteor
Posts: 927, Visits: 190.0K
the 53ford 1/2 ton i had the fuel tank was outside of the frame ,just as bad as being in the cab.
