Part 2: New Pics - Distributor Identification?
Posted By Danny 13 Years Ago
Danny
Posted 13 Years Ago
Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)Supercharged (367 reputation)
Posts: 132, Visits: 1.9K
Any guess as to what year distributor is? Install Pertronix II or III?
peeeot
Posted 13 Years Ago
Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)
Posts: 359, Visits: 25.5K
That looks just like my '57 original unit. It has the ball-bearing breaker plate that rotates instead of the pivot-type on later units. That straight-armed vacuum advance can is a bit scarcer and more expensive than the later style. I don't know for sure about pertonix but I would expect any of the Ford-intended ignitors would work as there is no distinction at the parts counter between points for the BB-type or pivot-type.
Mark F
Posted 13 Years Ago
Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)
Posts: 11, Visits: 622
I put the pertronic II in mine and all is good.
Grizzly
Posted 13 Years Ago
Posts: 281, Visits: 1.9K
there are pertronix units designed for either of the y block distributors. So there are pertronix I,II&III for up to 56 and pertronix I,II&III for 57 and later. the ignitor I can be used for a trigger for ignition units like the MSD 6AL. The II is a little more advanced and offers burnout protection (which the I hasn't) and the III is the top of the range.
I use the II as it offers burnout protection and a few other things over the ignitor without the expense of the III. My engine is basically stock. If I were to buy a unit for a modified motor I would be comparing the III agaist other aftermarket ignitions.
cheers
Warren
http://forums.y-blocksforever.com/Uploads/Images/41f30774-424d-428d-9c7a-e351.jpg Grizzly (Aussie Mainline)
