windlace installation
Posted By MplsMike 12 Years Ago
MplsMike
Last Active: 10 hours ago
Posts: 204, Visits: 92.3K
Hi,
I am installing windlace on my '56 Parklane and it isn't apparent to me how it goes in. I have an interior trim manual but instructions are very brief and not very helpful.
There are some tabs around the perimeter of the door that I think pinches the windlace. Does the windlace get pinched between the tab and the body? There isn't a great deal of material on the windlace to work with. Here are a few pictures of the tabs -- on one type it is quite apparent how it works:
http://forums.y-blocksforever.com/Uploads/Images/85a92716-0ce1-41a1-b0ba-19e5.JPG
http://forums.y-blocksforever.com/Uploads/Images/e100f9a8-aced-4d86-a4cd-0c76.JPG
http://forums.y-blocksforever.com/Uploads/Images/3134745a-20cb-408c-9068-19e6.JPG
Above the door, I assume the windlace gets held in place by the strip that is used for the headliner. I assume the sharp prongs are only for the headliner, though, and not the windlace -- correct?
http://forums.y-blocksforever.com/Uploads/Images/35cf8bc3-db4b-46fc-80cd-34f4.JPG
thanks,
MplsMike
'56 Parklane
Minneapolis, MN
rgrove
Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)
Posts: 498, Visits: 3.5K
factory way is to pinch it in the tabs. I think most upholstery guys use hot glue to hold in additional places. Problem with just the tabs (if you use the car a lot) is that it can pull out of position pretty easily if you regularly brush against it getting in and out, etc.
Ron Grove
Wauconda, IL
Frankenstein57
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
I wasn't happy with the results I was getting, so I installed some strips to screw the windlace to. I had some poly or plastic strips that were the correct thickness, so I cut and fastened strips to the areas. Some guys have used wood strips. Then I screwed the material down onto the strips. It.s all hidden by the panels.
thanks, Mark
