sallens
Visits: 421
Thanks guys for your help , i have now sorted the manifold out.....
i now need to sort the carb out..
the car came with a CARTER AFB CARB which i think i will try out before buying a new carb......
as i have no fixing instructions with the carb , can someone help me identify all the connections on the carb please.
many thanks
steve...............
peeeot
Last Active: 7 Months Ago
Visits: 25.5K
Hi Steve, Assuming you have an original style 2441SA vacuum-secondary AFB, the following two links should provide you with everything you need to know. http://fd988f0f1f3dea67447d-b985f6596ba7b0f27e47dfc537199edb.r39.cf2.rackcdn.com/afb_ford_2441s.pdfhttp://mercury1957.com/pdf_files/carter_afb_carburator.pdf
sallens
Visits: 421
thanks for reply
cant seam to find what vacum pipe goes to where on the carb any ideas?????????????
steve......
Posts: 3.0K,
Visits: 8.7K
You can trace each port by using an air hose, or a pressurized can of carb cleaner. Direct the spray or air into the outlet and see where it exits in the carb. Watch your eyes, don't get too close.
55vickey
Visits: 6.4K
There should be a small threaded one, I think on the front of the carb for distributor vac, been a long time since I've used one of these. Gary
Gary, 55 Vicky, St. Germain, Wisconsin
sallens
Visits: 421
here is a picture of my carb with the connections i need to identify .. 3 at the front and the top one in the middle on the side, i know that the 1 at the back on the left is the fuel inlet
55vickey
Visits: 6.4K
I'm pretty sure the small one on the lower rt. front is for the distributor, it's the only one I remember using. Gary
peeeot
Visits: 25.5K
I agree with 55vicky. I suspect the large front one is manifold vacuum for either a PCV valve or power brake booster, and the one on the passenger side top is a bowl vent to charcoal cannister.
Lucky 13
Visits: 343
Check out the edelbrock site for a user manual for a 1406 carb. Looking at the front of the carb the higher small port on the left is ported vacuum. The large center is manifold vacuum for power brakes or pcv. Lower right small port is also manifold vacuum if I remember correctly.
Jeff in Nashville
sallens
Visits: 421
I am still trying to find out what the outlet on the side of the choke is, just seen in one of the pictures
above what i have posted.......
i know what the three on the front are...........
steve....
