Ford Y Block Mallory Tach Drive Distributor w/ Pertronix Ignitor 3
Posted By Lucky 13 12 Years Ago
Lucky 13
Last Active: 2 Weeks Ago
Posts: 6, Visits: 346
For Sale: Ford Y-Block Mallory Tach Drive Distributor w/ Pertronix Ignitor 3 Ignition. Distributor was originally a dual-point but the points had to go. Distributor has only 8000 miles on it since new. Trying to keep my ride a 60's period custom so I swapped out the billet Mallory for a stocker w/ a Pertronix 3. If you don't know, the Pertronix Ignitor 3 is basically an MSD box without the big azz box and fits under the cap. It has multiple spark discharge, auto dwell adjust, an adjustable rev limiter and only a two wire hook-up. Throw that ballast resistor away, hook in a Pertronix Flame Thrower super low ohm coil and get all the power you can to your plugs.
Distributor new about $400.
Pertronix 7ml-181 $125 from Summit.
Take $350.
Jeff 615-972-5953
http://forums.y-blocksforever.com/Uploads/Images/a10b0198-bf1d-459d-a6f9-53eb.jpghttp://forums.y-blocksforever.com/Uploads/Images/d6a1d252-5eeb-4838-b988-1ee5.jpghttp://forums.y-blocksforever.com/Uploads/Images/76dc629c-cb3a-4d9f-b3e9-8d47.jpghttp://forums.y-blocksforever.com/Uploads/Images/7031d747-e096-4bc9-b260-4f08.jpg
Jeff in Nashville
