Need 239/256 small port 4bbl intake and have some parts for trade or sale.
Posted By 13bravo 13 Years Ago
Need 239/256 small port 4bbl intake and have some parts for trade or...
13bravo
Posted 13 Years Ago
Posts: 11, Visits: 66
I've been working on a project for a while now, and I need a 4bbl intake for the small intake port 239 heads.
I have an ECZ-9425-A manifold that I'd be willing to sell or trade.
I also have a set of new old stock Federal Mogul 963 M-30 .030 under main bearings for a 312 that I will trade for a set of std. size main bearings for the 239-292 engines. I will sell these for $150 plus shipping.
I also have a set of new old stock Sealed Power V-1285 intake valves for a 292/312. These are the 1.925 head size. I'll sell these for $75 plus shipping.
speedster1
Posted 13 Years Ago
Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)
Posts: 36, Visits: 336
13 bravo,
I have an ECZ-9425-A manifold>>> does this mean that you are looking for a ecz-b intake with the normal holley base>>>>> not like the -a intake which takes the toilet bowl holley?
I do have a -B intake, $100.
John
Is this the worlds first exotic automobile? The 1935 Harris fwd speedster, No heavier, higher, wider, taller or longer than an AC Cobra, but many many decades before.
http://www.autopuzzles.com/forum/index.php?topic=11958.0
13bravo
Posted 13 Years Ago
I'm not sure what the small port manifold casting number is and a search here didn't get me anywhere. The A manifolds ports are too big for the heads.
pintoplumber
Posted 13 Years Ago
Posts: 1.0K, Visits: 164.3K
I have an offy 3x2 for the 239 and know of a 2nd one if you want to go that route.
Ol Ford Guy
Posted 13 Years Ago
Posts: 323, Visits: 2.4K
I have an early 4 barrel intake. It has been hot tanked and preassure tested. It has an extra tapped hole on top, probably for a vacuum gauge. It could be used or plugged. I could check the part number tomorrow and send you a picture.
Paul J. - '57 E Code
Posted 13 Years Ago
Last Active: 8 hours ago
Posts: 3.7K, Visits: 323.4K
13bravo:
What you are looking for is a '54 Merc manifold. Good luck.
13bravo
Posted 13 Years Ago
Hoosier Hurricane (4/17/2013)
13bravo:
Do you happen to know the casting number on that manifold?
As for the 3x2 setup the owner doesn't want to go that route for some reason or other.
If I had known the problems I have run into beforehand I would have talked the owner into going a different route.
Posted 13 Years Ago
13bravo:
The '54 Merc manifold casting number is EBY-9425-D. Sorry for the delay,I had to remember where I had the information.
iowa fords
Posted 13 Years Ago
Posts: 138, Visits: 3.9K
I have a garage ful of 54 Merc stuff, I will check to see if I have 1 left
tom in iowa
54 Merc wagon
54 sunvalley
Ol Ford Guy
Posted 13 Years Ago
The manifold I have is an ECZ9425A, which you already have. It has 2 holes drilled in it. Does anyone know why these holes may have been drilled in the manifold? I wonder if it is of use to anyone. I will attach a picture.
http://forums.y-blocksforever.com/Uploads/Images/2f6d664a-2c62-4110-99ab-36ec.jpg
