A Good Idea for all that Y Block Hardware...
Posted By Daniel Jessup 13 Years Ago
GREENBIRD56
Posted 13 Years Ago
Posts: 1.7K, Visits: 102.7K
I use the "purple stuff" grease killer to emulsify the oil on parts and it works pretty well - I think it came from Wally World too. They have a big jug with about three gallons in it. A good spray soak with it in an old plastic bucket is a quick "first shot" before beginning any of the other treatments.
After all of the magic tricks are done - here's a tip from a restoration guy I met .....next use "Birchwood Casey" Perma Blue - Liquid Gun Blue to put a controlled corrosion coating on the surface of the hardware. It is found next to the gun cleaning supplies at many sporting goods stores - little blue three Oz bottles are common. The active ingredient of the stuff is "Selenium Dioxide" - follow the directions please. It will turn your cleaned (washed, neutral rinsed, and dried) hardware a nice shade of Black. I put a bunch of dry small parts in a zip lock with just enough of the stuff to wet every surface. Shake it out onto an old newspaper to dry. You can paint over the finished surface - or oil it with motor oil.
The Master Cylinder
Posted 13 Years Ago
Posts: 974, Visits: 6.2K
MoonShadow (3/24/2013)
Do a search for Caustic soda. The formulas and instructions are online. You can buy the powder at your local hardware store. This stuff has to be mixed in a plastic tub. Definately attacks metal. But the fall out is that it is an acid. That mean elbow length rubber gloves and eye protection. A rubber apron wouldn't hurt. I don't want to scare you off but when you have a bunch of small parts to do it mayrbe worth making some up. As far as disposal thats up to you, I don't know the EPA requirements for it. I've seen the reverse chrome setup with the electrodes and it seems to work. I don't know anyone who has tried it. Chuck
Actually Caustic Soda (sodium hydroxide) is an Alkali with a high pH, opposite an acid. Think Lye. But regardless, heed Moonshadow's warning and use proper safety protection. May want to refer to the MSDS for more info.
There was a discussion on The Ford Barn about rust removal using Molasses. Haven't tried it personally but quite a few said it works great and is environmentally safe... w00tw00t
I have used Evapo-Rust with good results. Evapo-Rust
stuey
Posted 13 Years Ago
Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)
Last Active: 10 Months Ago
Posts: 444, Visits: 3.8K
fascinating thread
years ago i looked at ultrasonic cleaners. most were very small and used in the jewelery trade. bigger versions were just too expensive.
small ones used peiziolectric transducers and larger ones used magnetostrictive transducers (buzzy transformers) these may be added to existing tanks but you may have to have some sort of frequency control all beyond my capabilities. years ago there was an article in HR magazine with a carb using peiziolectric technology.
re caustic soda (oven cleaner) be careful how you mix it. now i am not sure which way is correct so do some research but i think you must add it to a bucket of water if you add water to the caustic it can get pretty violent.
for not too serious rusty parts i use phosphoric acid , its in Coca cola, sometimes sold as Metal Prep.
re molasses sounds real good but i have not been able to track it down over here. is it called "strap molasses"if so is it different to any other kind??
stuey
UK
The Master Cylinder
Posted 13 Years Ago
Be extremely careful when mixing caustic soda. Mix it too fast will cause a violent, exothermic reaction.
Posted 13 Years Ago
Chuck, be REAL careful with the heat idea. You have no idea how much you're speeding up the reaction, and it could be too much. Master's correct about the not an acid part. A caustic is actually the opposite of an acid. Still burns you though. Remember your high school chemistry?
Posted 13 Years Ago
Posts: 4.6K, Visits: 39.5K
I'm pretty sure that I slept through Chemistry. Don't remember though. I was talking about heat with the solvent in the parts washer not with anything else. I know there are ultrasonic tanks out there big enough for car parts like in Jay Leno's garage (car palace). But they are very expensive. I am certainly no rocket scientest so that is why I've been looking for someone that can work out the details for adding ultrasonic to an existing tank. I would think if it could be done reasonably an adapter kit could be marketed to the home garage folks. Maybe even the regular garages. Chuck
The Master Cylinder
Posted 13 Years Ago
pegleg (3/25/2013)
You reminded me of high school auto shop and the heavy duty "Parts Cleaner". Don't know what the solvent was in it but it was heated and got parts REAL clean. Thinking back they would never allow a bunch of teenagers these days anywhere near it.
Anyway, one of the guys put an aluminum head (Fiat I think) in it and left it in over the weekend. w00t Destroyed the head. With all the craters eaten out of it there was know way you could mill the head enough to get it flat. Even all the valve seats fell out. Shop teacher was PO'd.
Posted 13 Years Ago
We did that with a VW engine case and a 50 gallon drum of ZEP (RIP EPA). We had it soaking during the afternoon but forgot to take it out before leaving. The next morning it had holes through the thin parts of the case. GREAT parts cleaner but real nasty stuff for the ecology. Chuck
Pete 55Tbird
Posted 13 Years Ago
Posts: 721, Visits: 93.2K
Rust removal can be SAFE and CHEAP and CLEAN. Do a youtube search of rust removal using electrolysis and watch a few videos. Just remember do not use stainless steel for the sacrificial anode as that will produce TOXIC FUMES.
This flat out works and gets behind panels and inside blocks and otherwise inaccessible parts. Check it out. Pete
wlj1943
Posted 13 Years Ago
Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)
Posts: 30, Visits: 780
Mark,I noted the same thing about CLR.
I have used the vibratory for years for small parts; key is the right media and everything dry and no grease or oil beforehand.
I prefer to de-rust electrolytically, especially for valuable or machined parts, but it can be kind of slow, needs monitoring and takes a good filtered DC power supply. Also you must do it outside as the process emits hydrogen, but it removes only "rust". Lots of references to this on the internet; I first used a article about this in the Model T club magazine circa 1990.
WLJ
