Y block Billy
Posts: 1.6K,
Visits: 5.2K
Does it matter which way they go and what are your opinions? should they be parallel to the rocker or 90* to the rocker?
The Bat out of hell
Visits: 355
In a perfect world,the valves rota some and so do sping ect,so no don't matter,kind of like putting in rings,good the be sure there stagered gap wose,but they do move when new running
"The Bat" out of hell
50's & 60's hotrodder
retired speed shop owner,built and design hotrods, racecars
airbrush t-shirts, engine balancing
Miami fl.
Posts: 1.4K,
Visits: 179.6K
Hmmm.... 'The Bat' is correct... IF you are using the original FoMoCo 'usual production' y-block valve spring retainers. The FoMoCo two piece valve spring retainers were designed to cause the valves to rotate during normal engine operation to prolong valve life. However, IF you have original '57 'E' or 'F' code single piece valve spring retainers, OR aftermarket single piece valve spring retainers from performance camshaft kit or component suppliers, the valves do not rotate and therefore the valve keepers retain their 'as installed' orientation. Perhaps Ted, John Mummert, or McTim will have a comment as to whether they pay attention to valve keeper orientation on single piece valve spring retainers when they assemble cylinder heads having them...
Posts: 3.3K,
Visits: 238.8K
Which brings up the subject of original 2 piece valve keeper/retainers vs aftermarket ones that are usually one piece. Why one piece? Are 2 piece units unreliable with higher spring pressures or in high performance applications??
Posts: 1.4K,
Visits: 179.6K
I like your question, too, Paul. Is it a matter of fewer valve train components resulting in less weight / inertia in the valve train? Is it simply a matter of assuring valve train reliability at high rpms?
Posts: 7.5K,
Visits: 205.9K
Makes no difference in how the keepers are clocked. And with single piece valve spring retainers, the valves do still rotate. That’s simply a result of the angle of the coil in the springs promoting the rotation.
Here’s a video that helps to demonstrate how much rotation can occur in the springs. http://www.youtube.com/watch?v=6Vz4mjPKXJ0
One piece retainers are favored in a high performance application due to being able to handle increased valve spring pressures without a retainer failure while at the same time being lighter. Titanium is the material of choice for single piece retainers in a high performance application when the budget permits it.
Y block Billy
Posts: 1.6K,
Visits: 5.2K
What about during the first few minutes of break in before the valves start rotating and the keepers are seating, would there be a preferred clocking of them? I am using the one piece.
Posts: 1.4K,
Visits: 179.6K
INTERESTING. Thanks, Ted!
lyonroad
Visits: 3.1K
Ted, that video is something. With that much rotation, combined with the pressure and the fact that the rotation is against the bottom turn of the spring you wonder why they don't drill themselves into the head in no time.
Mark
Y block Billy
Posts: 1.6K,
Visits: 5.2K
Something doesn't appear right with that video, that spring is turning 2 revolutions for every rocker lift, I watched other videos, the one of the valve spring at 7000rpm and that spring wasnt turning but 1/16 per rocker lift, I also watched a few other videos but they were overhead cam and could not really see the turning action well. I know the valves and springs turn and such, but that appears excessive and it does not stop when relaxed, I can see it revolving a quarter turn or so after each compression from the rocker but it should slow down or stop between compressions shouldnt it?
