292 rocker arm shaft plugs who has them?
Posted By hobbyjp 12 Years Ago
hobbyjp
Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)
Posts: 8, Visits: 45
Hows everyone, I'm rebuilding some 292 rocker arm shafts and I want to remove the plugs to clean out the old gunky oil but before I pull them out I want to make sure I can get new ones and so far I cant find them anywhere. I have a part number 6572 but thats from an old manual. Any help would be appreciated.
I might be corrected, but I believe the rocker shaft plugs are the same as F.E. engines.. 352-390 etc
Teros292
Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)
Posts: 129, Visits: 12.3K
Yes, those are same on FE engines and also on some six cylinders. Found them on ebay:
Ford plug #EAA6572A expansion
Tero from Nurmijarvi, Finland
56 Country Sedan, 61 F-100, 61 F-600, 55 F-620, 52 Mercury
Tee-Bird.com stocks them.Try that part# in their online catalog.
Posts: 3.7K, Visits: 323.1K
NAPA has them if you can find a counterman who can look them up. They are .540 diameter, NAPA number 219-2098 iin my old catalog.
lowrider
Posts: 479, Visits: 10.9K
I picked up some from Greensales.com a few years ago but they were expensive from them.
hobbyjp
you guys are awesome thank you
hobbyjp
Just an update I got the plugs and installed them the napa part number is 381-2098
