By hobbyjp - 12 Years Ago
Hows everyone, I'm rebuilding some 292 rocker arm shafts and I want to remove the plugs to clean out the old gunky oil but before I pull them out I want to make sure I can get new ones and so far I cant find them anywhere. I have a part number 6572 but thats from an old manual. Any help would be appreciated.
By PF Arcand - 12 Years Ago
I might be corrected, but I believe the rocker shaft plugs are the same as F.E. engines.. 352-390 etc
By Teros292 - 12 Years Ago
Yes, those are same on FE engines and also on some six cylinders. Found them on ebay: Ford plug #EAA6572A expansion
By oldcarmark - 12 Years Ago
Tee-Bird.com stocks them.Try that part# in their online catalog.
NAPA has them if you can find a counterman who can look them up. They are .540 diameter, NAPA number 219-2098 iin my old catalog.
By lowrider - 12 Years Ago
I picked up some from Greensales.com a few years ago but they were expensive from them.
you guys are awesome thank you
Just an update I got the plugs and installed them the napa part number is 381-2098
