T54P-3044-A
Posted By Genuinerod 12 Years Ago
Genuinerod
Posts: 120, Visits: 33.3K
I'm looking for all or part of T54P-3044-A front suspension set.  I have some pieces but want to collect the whole set.  Anybody know of any?  Thanks.
Many people on here, including me will not recognize the part #s you gave, but might be able to help with a more specific word description. Also, your general location would be helpful re shipping etc.
Genuinerod
Sorry for the confusion.  I'm not very good at this.  This is the 8 piece front suspension upper and lower arm overhaul tool set that Ford used to replace the bushings on the cars from 1954 to 1956 including all little T-Birds.  T(tool)54(year)P(passenger car)3044(front suspension number)A(last revision).  They added at number at end of the A (in this case 5-13) for identifying the pieces.  I have two of pc 10, one of pc 7 and looking for the rest.  Thanks
lowrider
Posts: 479, Visits: 10.9K
If I remember correctly I used the ball joint tool kit available from Snap-on or Matco to press my bushings in.
chiggerfarmer
Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)
Posts: 85, Visits: 3.8K
It is great to have the correct tools, but these bushings can be installed easily with a hammer and home made driver. I drove the old ones out with an air chisel and then chose a pipe nipple that fit the bushing and put a pipe cap on it to strike. Just be sure to support the control arm so that it is not stressed. I assume you have the arms off? The Ford dealer where I worked had these tools but they were so disorganized we did not even bother to look for them most of the time.
Tom from the chiggerfarm located in the beautiful Heart of Central Texas
When you cannot dazzle others with your brilliance, baffle them with bullcorn! BigGrin
