Does anybody know where I can get...
Posted By Daniel Jessup 12 Years Ago
Daniel Jessup
Last Active: 9 hours ago
Posts: 2.0K, Visits: 130.9K
A good set of casters/wheels for my engine run stand? When I bought this thing a few years ago, it came pretty simple, and I have upgraded along the way. The initial cast iron wheels for concrete/hard surface only were only 4 inches tall. I could not get my engine lift under the stand to put a block on it... quite frustrating. Anyway, I subsequently purchased a set of 8" tall pneumatic caster tires as you can see. They worked well for about 6 months... seems the SHEET METAL that the rims were made of were pretty thin and not able to stand up to the 300 lb rating per tire (maybe I overloaded them anyway). I continue to have trouble moving it around the shop but do not want to go back to the cast iron wheels. I have considered purchasing one of those small trailers like they have at Harbor Freight and then simply using a Tow Bar Dolly I have. This would mean I could hall this thing inside and outside and then simply hook the hitch to the ball and away we go with Y block Eye Candy. But then again, I would only use that small trailer for just this purpose.
Anybody have any good ideas? BigGrin
By the way, the above pics show a new permanent tach, an electric switch operated cooling fan, the radiator I got from Alan Freeman (thank you Alan!), and the good Holley 390cfm from Cactus. This thing rumbles even if it is a 272. Once I get all of these kinks worked out the way I want them to, it will be ready for my 312, 30 over build that I am doing on that C2AE block. This 272 on this run stand is not quite an all out rebuild, but it has great compression, new bearings, a little head work, new timing chain, gears, etc. Pretty much stock, but she is for sale, lol. Tongue
Great story.... I live in a community where on a gravel road, we all have 2+ acre lots. Most of the time in the summer, the foliage is so dense I cannot even see any of my neigbors' buildings. Recently, I installed a new cam and lifters and ran the Y at 2000 rpm or so for 20 minutes like we normally do. This was in the afternoon about 4 pm or so and I had pushed this run stand outside on the driveway. After I broke everything in, checked for leaks, etc. I shut it down. It was quiet for a split second or two and then I heard this guy that had to be a few doors down from me... i did not recognize his voice and I know most of my neighbors... He yells out, "Thaaaank Yoooouuu" and that was it. I don't know if he heard me or not but I yelled out, "You're Welcome!" Cool
Daniel Jessup
Lancaster, California
Posts: 1.9K, Visits: 194.9K
Try W W Grainger, we used them for casters on gang boxes on job sites, way over this weight.
Posts: 6.1K, Visits: 442.9K
Northern Tool carry Fairbanks casters which are made in the USA.
Frankenstein57
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
Daniel, sweet run in stand, got me thinkin........
thanks, Mark
lyonroad
Posts: 703, Visits: 3.1K
Daniel, I saw your motor on ebay today, sounds good. It's too far away for me but maybe your neighbour would like to own it. lol
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
