Horsepower surprise when using the ECZ-A Teapot Intake.
Posted By Ted 13 Years Ago
Dave V
Posted 13 Years Ago
Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)
Posts: 234, Visits: 41.5K
I'm in the process of putting together a 312 with an Isky E4 cam that I thought I would advance 2-4 degrees to improve low end grunt. Will slotting the B intake help me any more on low end?  Dave
SE Wis
Posted 13 Years Ago
The overall torque will be improved by slotting the manifold but that improvement will only show up after 3000 rpms.  If you’re upgrading the camshaft, you’ll still want to slot the intake regardless of the slight dip in torque that will occur at 2000-2500  rpms as a result of slotting the manifold.
Posted 13 Years Ago
charliemccraney (12/18/2012)
... Ted, how does the low end compare with the different carbs?
DryLakesRacer (12/19/2012)
Great info Ted. It will be interesting to see the the smaller carb HP up to 3500. If you have the torque numbers that would be great too.........Thanks again for your work...........JD
Here are charts showing horsepower and torque using the ECZ-A intake with different carbs.  It still boils down to fuel metering and not necessarily the carburetor size.  But for all intent and purposes, all three carbs are reasonably close to each other on the ECZ-A’ intake manifold.  And when considering that there is ~55 years between the Lincoln Teapot and the 750HP Holley, the Teapot holds it own quite well on the ‘A’ manifold.  We’ll see what happens though when the Lincoln Teapot is matched up to the ECZ-B intake shortly.
Horsepower – ECZ-A Intake with various carbs
Rpm
Lincoln Teapot
600 Holley vac sec
750HP Holley vac sec
2500
141
144
147
3000
184
182
185
3500
213
204
211
4000
227
215
228
4500
237
233
238
5000
236
237
240
Torque lbs/ft – ECZ-A Intake with various carbs
Rpm
Lincoln Teapot
600 Holley vac sec
2500
296
303
309
3000
323
318
324
3500
319
307
317
4000
299
283
299
4500
277
271
278
5000
248
249
257
Dave V
Posted 13 Years Ago
Thanks for the info Ted.  Dave
SE Wis
56_Fairlane
Last Active: 10 Months Ago
Posts: 575, Visits: 14.6K
Ted, this info is great. Thanks for sharing it with everyone.
~DJ~ AKA "Bleach"
