Richard
Visits: 81.0K
T-86 with overdrive, includes governor, and solenoid $400 cash. Works but needs gaskets. Shifts good.
Posts: 1.4K,
Visits: 179.6K
Hi Richard, I have been schooled to believe (by this Forum) that the Borg Warner T-86 transmission has a sheet metal top-mounted-cover which provides access for installing and removing gears, etc. Too, the shift levers come through the side of the transmission case casting and are not part of a removable cover on a T-86 I'm not sure what you've got from your picture. I wish I could be more help.
Richard
Visits: 81.0K
This came out of my 54 Ford Ranch Wagon. The Overdrive is an R10. This will fit 54-57 Ford. I believe it to be a light duty 3 spd with overdrive. I may have erred the T86 nomenclature The Transmission numbers on the are:
Last Active: 5 hours ago
Visits: 322.9K
To use it in a '57 the driveshaft yoke will have to be changed. Ford went to a fine spline in '57. The '56 and earlier yoke will require a hybrid U joint to make the connection.
ejstith
Visits: 1.0K
A C6 front yolk works on a T-85 . Like John said, have to have a combination U-Joint....
E.J. in Havana FL
Visits: 322.9K
EJ: This is a light duty trans. A C6 yoke won't fit.
ejstith
Visits: 1.0K
John, I've got one in my car.....
E.J. in Havana FL
ejstith
Visits: 1.0K
And it ain't a light duty... It's a T-89. I made one good one out of 2 that I got at Moultrie swap meet...It has a 31 spline tail shaft & I got a new C-6 yolk & it slides right on. Perfect....
E.J. in Havana FL
ejstith
Visits: 1.0K
Oh, I see........ crap... I got things confused here, his is a T-86... True... C-6 won't fit...It's hell gettin' old...... !!!
E.J. in Havana FL
slumlord444
Last Active: 6 days ago
Visits: 137.8K
T86, straight bottom side cover is the light duty trans. T85, curved bottom side cover it the heavy duty one. Came out in the 312 cars in 1956 and as I recall was available in the '62-'63 406 Galaxies.
