I have for sale everything needed to convert a FOM car to three speed,either with a 56 three speed transmission or a 56 three speed with OD.Includes all brackets,everything under the dash,resurfaced flywheel,nearly new clutch disc and pressure plate,bell housing and all linkages,etc.I'd like to have $500.00 for this setup.
I also have a good running 292 for sale.I pulled this from a 90,000 mile car a couple of years ago and tore it down.It was very good inside,so all I did was hone the walls and put in a set of rings.The bottom end looked good and all bearing clearances were good,so I didn't replace the main and rod bearings.I did replace all the seals and gaskets and cleaned all the oil passages.It runs good and doesn't smoke or use oil.I also want $500.00 for this engine.
I also have a lot of other engine and drivetrain and body parts for 55/56 car.
I can't ship any of this stuff,so it would have to be picked up at my house.Or I'll deliver them for expenses.
Email me at ph101842@yahoo.com or phone 660-888-2213.
Paul,
Boonville,MO
