MoonShadow (7/27/2012)
Ted, When you dyno'd my new engine did you use my valley cover and the PCV valve thats in it? I bought that one on size to fit the hole and not by engine size. It could be too big and possibly be part of my erratic idle problems? ChuckChuck. While your aluminum valley cover had a threaded hole at the back of it for a screw in style of PCV valve, it has a plug in the hole. I did not find a PCV valve in your pile of parts. The flat bowl Holley carb you provided did have a hose on it though but no PCV valve sticking on its end. Your engine so far has been run without a PCV valve. That’s simply due to the engine being run with the roots blower and not the McCulloch unit. At this point, it’s been more expedient from a testing standpoint to not have PCV in place. When I get the engine back on the dyno, I’ll fit a PCV valve to it so it’s tuned with the valve in place.
