How you get the Idler arm off -1957 fairlane
Posted By drof75 12 Years Ago
drof75
Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)
Posts: 35, Visits: 248
How you get the Idler arm off? It appears that the bushing is threaded on the outside in the opposite direction of the arm itself. Does this mean I need to get the arm loose from the frame first. Them unscrew the arm from the link and do the same to the other side that's in the mount that goes to the frame. I hoping I answered my own question. I just need to be sure. Thanks in advance
Buz
Buz Mills
Dallas, TX
aussiebill
Posts: 1.8K, Visits: 11.4K
drof75 (7/8/2012)
Buz
Pretty much right on. one handy hint is to loosen nut on the drag link end first, then remove frame brkt, then unwind as you mentioned. i allways grease threaded parts when refitting and take note not to screw the arm all the way in as to bottom out in nut, as the arm needs to swing left and right when steering is turned, Smile
 Down Under, Australia
drof75
Thanks Bill. That is actually how I did it. All is good. Good thing I stopped when I did the impact was about to come out. Smile
Buz Mills
Dallas, TX
