4 Speed for 56 Y-Block
Posted By Fifty6Vicky 18 Years Ago
Fifty6Vicky
Posted 18 Years Ago
Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)Hitting on all eight cylinders (20 reputation)
Last Active: 14 Years Ago
Posts: 20, Visits: 406
My retro-cruiser (56 Customline Vicky) needs some oomph! I want to swap out the original 3 spd -no o/d for a good 4 spd with minimal hassle. What should I look for in the 'yards' that will bolt on if possible. I have a 57 9inch (3.10) already in but just for the street, would prefer a good 4 spd. for cruizin'.
pcmenten
Posted 18 Years Ago
Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)
Posts: 375, Visits: 1.1K
Is that a Rochester in between the Holley 94's?
I'd suggest the top-loader. I have a RUG O/D that might end up going into a 54 F100.
Best regards,
Paul Menten
Meridian, Idaho
Fifty6Vicky
Posted 18 Years Ago
You've got a sharp eye for carbs. It works well though.
Posted 18 Years Ago
Posts: 3.6K, Visits: 497.6K
I have a top loader in my 54 (312). I like it. Minimal trouble to put it in. See some of my prior posts on mods required.
rexbd
Posted 18 Years Ago
Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)
Posts: 128, Visits: 1.5K
Go with a top loader, very sturdy and easy to rebuild not to expensive to buy.  Number of good websites to look up information on gear ratios rebuild kits etc.  David Kee is a good source as is Toploader Heaven.  There are two basic kinds with the difference being the size and number of splines on input shaft.
morgus
Posted 17 Years Ago
Posts: 31, Visits: 1.3K
NICE COMBO- BUT IF YOUR 4 SPEED DOESN'T HAVE A STEEP FIRST GEAR, I DON'T THINK YOU ARE GOING TO LIKE THE SLOW GETAWAY FROM REST. YOU MAY WANT TO ADD MORE GEAR TO YOUR REAR END-SOMETHING LIKE A 3:50 OR 3:73, EVEN 3:90. AUTOMATICS GET AWAY WITH THIS BY HAVING A BUNCH OF GEAR IN THE TORQUE CONVERTER. HAVE FUN. BYE.-
Posted 17 Years Ago
I'd recomend a small block-wide ratio 4 speed, the one with the 2.78 low gear.
Mummert makes an adapter to utilize a t-5 from a 5.0 Mustang, that would give you a healthy low gear, in the 3.0 range and the 70% overdrive. Use that and a 3.50 or 3.70 rear gear and you'll have the best of both worlds. Wink
Ol Ford Guy
Posted 17 Years Ago
Posts: 323, Visits: 2.4K
Frank,
Can you tell externally which gear set is in a T-10, assuming it hasn't been changed?
Paul J. - '57 E Code
Posted 17 Years Ago
Paul,
       Easiest way I know is to put in low, rotate the input shaft and count (the output will rotate once for every 2.2 or 2.54 times you turn the input). You'll know what it's actually got this way. I usually mark the shafts with a marking pen and do it a couple of times to be sure I got it right. Not that I ever screw up but........w00t
