rear seal
Posted By yblock32deuce 13 Years Ago
yblock32deuce
Posted 13 Years Ago
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 173, Visits: 1.5K
so, getting started on a customer's 312, and am using the neopreme seal for the obvious reason, but was thinking instead of installing this flush with the block, to offset it 1/8" or so,and do likewise with the top half. thinking this might eliminate another potential leak area. anyone ever done this,or have any thoughts about this?Smile
petew
Posted 13 Years Ago
Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)
Posts: 178, Visits: 5.0K
I do that on all my FE motors and they seal up great.
Posted 13 Years Ago
Posts: 3.6K, Visits: 497.6K
Definitely
Talkwrench
Posted 13 Years Ago
Posts: 898, Visits: 23.2K
someone put up Ted's link to show how its done..BigGrin
slumlord444
Posted 13 Years Ago
Posts: 1.2K, Visits: 137.6K
Would also like to see exactly what is being described. Will be installing one of these soon.
Posted 13 Years Ago
Last Active: 7 hours ago
Posts: 7.4K, Visits: 205.6K
Offsetting the neoprene seal ends in their grooves simply insures that the seal ends are actually butted up to each other.  If not offset, then the rear main cap (FE) or the seal housing (YBlk) can be mismatched just enough that the seal ends are not aligned with each other.  Here’s the link to the comprehensive seal installation instructions.
http://www.eatonbalancing.com/blog/2008/09/10/neoprene-rear-seal-installation-for-the-y-and-others/
slumlord444
Posted 13 Years Ago
Thanks for the link. Makes perfect sense. A picture is worth a thousand words.
