Aluminum head spark plug torque
Posted By Ted 14 Years Ago
Posted 14 Years Ago
Last Active: 11 hours ago
This is for Marv.  I’m having trouble with the private messaging so I’m posting the answer to your question here.
By the book and for aluminum heads, 8-12 lbs/ft torque for spark plug tightening.    Be sure to use anti-seize on the threads.
marvh
Posted 14 Years Ago
Posts: 513, Visits: 16.7K
Thanks Ted.
marv
Posted 14 Years Ago
Charlie sent me this link to a NGK technical bulletin.  It’s worth reading in regards to spark plug plating and the use of anti-seize with certain spark plugs.  http://www.ngksparkplugs.com/pdf/TB-0630111antisieze.pdf
Posted 14 Years Ago
In looking at the AFR instructions for their heads, they do not recommend using torque wrenches on the aluminum heads when installing the spark plugs.
Here’s the exact text from their instructions:
  Intake, exhaust bolts, and spark plugs: We suggest not using a torque wrench on these locations as commonly inaccurate torque wrench values can easily strip the smaller threads.  Just snug up hand tight with a wrench only.
Posted 14 Years Ago
Which is exactly why many of the early Detroit aluminum heads used "threadserts." The much larger od threads would stand a lot more torque on the bolts and the steel threadserts could handle repetitive use.
Posted 14 Years Ago
Then the only problem is what is "hand tight." A guy my size probably couldn't do any damage but what about someone 50 - 100lbs bigger?
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
charliemccraney (6/2/2012)
Charlie, bit like thinking about how hard do you squeeze an egg, like anything there is a feel related tension, tighten to light nip then tighten slowly till you feel it get harder, not keep going indefinitly, then another nip and should do it, its not in tension like a bolt and nut, i would never use a tension wrench on any bolts under 3/8", thats my take on it. Smile
 Down Under, Australia
Posted 14 Years Ago
Last Active: 44 minutes ago
Posts: 4.6K, Visits: 39.3K
I use a 3/8" ratchet and hold it by the head instead of the handle. Works on intakes, spark plugs etc.. Works for me! Chuck
Posted 14 Years Ago
But that's the problem, Bill, you have to break a few eggs before you get the feel for how tight you can hold one. Hand tight doesn't give any kind of reference for someone without experience. At least with a clicker wrench there is some reference. I'd hate to be the guy who stripped my bran new heads because I got them what I thought was hand tight. It's open to interpretation, and that is where I see an issue. Not everyone who tackles the job will have years of experience and know the feel or have developed a method.
aussiebill
Posted 14 Years Ago
Charlie, you,re exactley right on all points, does require some expeirence, i would just assume most car guys have some feel for tightness. We,re into autumn fall here, raining and miserable. best regards bill.Smile
